No longer high Idle when cold?
Old Feb 4, 2008 | 10:23 AM
'99 STROKE's Avatar
'99 STROKE
It's been -20 here and my high idle doesn't work. Is the AIT known to go bad.
Old Feb 4, 2008 | 07:19 PM
griesera's Avatar
griesera
Mine does the same thing, its in the teens here at night, i don't have it plugged in and i cannot get the high idle to work. It did last year, but i have noticed one thing, with my park brake set my park brake light does not come on the dash. I wonder if it's not registering to teh computer that my brake is set?? I guess there is a sensor that might have gone bad by the pedal??
Old Feb 4, 2008 | 07:21 PM
Golflug's Avatar
Golflug
I pulled the air cleaner today and found some dirt on the air temp sensor. I tapped the dirt off with my finger and then this morning the engine idled up normally, so I'm assuming the sensor may be bad. Autozone carries the sensor for about $15.00 so it's worth the cost to install a new sensor.
Old Feb 4, 2008 | 09:32 PM
ballbandit's Avatar
ballbandit
Ford 79 is right because i unhooked mine when i put the bigger air filter on and it wouldn't idle up until i hooked it back up. Another thing is since i put the dp tuner in on any level but stock it won't idle up.
Old Feb 5, 2008 | 12:06 AM
twags6's Avatar
twags6
If the light isnt coming on, the computer isnt seeing the brake set. There's just a simple little tab that grounds out when you push the pedal down. Its basically like a door switch for the interior light. Some wd-40 should clean it up. Look up near the rubber bumper the pedal hits when you release the brake.
Old Feb 5, 2008 | 12:08 AM
twags6's Avatar
twags6
Since it idled up, the sensor is still working. The dirt was probably keeping it a little bit warmer and not letting it sense the real temp. If you touch the sensor while the idle is up, it drops almost instaly due to the warmth of your fingers.
Old Feb 10, 2008 | 10:57 AM
Golflug's Avatar
Golflug
we'' I finaly got the sensor from the zone and it is not an exact replacmet. It mounts differently and you need to install a new style plug for the unit. I installed it anyway and it did not make any differance. It still will not idle up when cold. The ebpv is closing, but no high idle. Guess I'll keep looking :-(
Old Feb 10, 2008 | 07:48 PM
twags6's Avatar
twags6
Is your truck auto or manual? If its manual, check that the brake light on the dash turns on when you set the parking brake. If it doesnt, the pcm wont see it as being set and wont idle up.
Old Feb 10, 2008 | 10:07 PM
griesera's Avatar
griesera
after i wrote that i went out and checked it and the park brk sensor was sticking, i got it to work now...all is good!! Thanks a bunch!!
Old Feb 11, 2008 | 08:09 PM
Golflug's Avatar
Golflug
mine is an auto, but I'll check the brake switch just the same
Old Feb 11, 2008 | 09:38 PM
griesera's Avatar
griesera
I wonder if you might happen to have a loose connection to the AIT sensor and the tappin made it temporarily get connection??
BikeNHV
26
Jul 22, 2017 03:01 PM
pba369
Jul 12, 2016 07:37 PM
navistarnut
Dec 2, 2015 08:30 PM
pog23
6.4L Power Stroke Diesel
Sep 4, 2010 04:25 PM
Mookie
Jan 31, 2003 06:49 PM
