Superduty x codes
Old Feb 1, 2008 | 07:01 PM
F0rdF0rever's Avatar
F0rdF0rever
Superduty x codes
I started to install my X code front springs today. This is by no means a light task. It took me 2 hours just to get the old u bolts apart. It took about 4 hours to get it all completely apart. Now it sits in the shop ready for the new springs in the morning. I need to hit the dealership in the morning and grab a few more parts. I found I am going to need new u bolts, new spring bushings and new bolts for the spring eyes. The superduty eyes are larger than ours. Hopefully the will have what I need in stock.
I still need to remove the rear shackles from my springs to install on the new ones. Any tips for getting those off?
Tons of pics to come when im done.
Steve
Old Feb 1, 2008 | 07:05 PM
tjbeggs's Avatar
tjbeggs
600 ft lb Impact wrench held wide open for about 5 minutes. So your doing the reverse shackle by moving the front spring mounts?
Old Feb 1, 2008 | 07:06 PM
tjbeggs's Avatar
tjbeggs
BTW we want lots of Pics and measurements!!
Old Feb 1, 2008 | 07:12 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i had a set of sd springs that i threw away a while back because i didnt think they would work on my other truck. i guess you would have to do the shackle mod to take up for the length difference?
and use a 2135TI IR impact gun, they come off really quick
Old Feb 1, 2008 | 07:19 PM
tjbeggs's Avatar
tjbeggs
Good impact isn't it Joe? I like mine! that TI is very nice when doing FWD alignments tightening and loosening strut to knuckle bolts!!
the SD springs will fit with a reverse shackle and the front mount moved 4 or 5 inch forward which runs into the bumper so you either have to space your bumper out 3 or 4 inchs or knotch it or build a custom bumper.
Old Feb 1, 2008 | 07:21 PM
Action4478's Avatar
Action4478
600 ? You're fallin behind ..We've got a 1000
Old Feb 1, 2008 | 07:27 PM
tjbeggs's Avatar
tjbeggs
Yeah the 2135ti claims a 1000 but I've never seen it with 130 PSI and huge quick connects. It rated at 625 forward and 700 reverse. Maybe I should just hook it up to the 1/2 inch hose we use for the 3/4 impact! Get your ear muffs out. Tim's gonna break some bolts!
Old Feb 1, 2008 | 07:44 PM
Action4478's Avatar
Action4478
We have a couple of bolt breakers here,,,Take my word for it (unfortunately)1/2 drive & 3/4 @ 160 ( I have it turned down )....
Old Feb 1, 2008 | 07:47 PM
tjbeggs's Avatar
tjbeggs
Very nice!! gonna have to remember that!
Old Feb 1, 2008 | 07:48 PM
Action4478's Avatar
Action4478
need something broken?.....
I'm the man....
Old Feb 1, 2008 | 08:45 PM
F0rdF0rever
Measurements and pictures for sure guys. I think I forgot to mention I already had a rsk installed.
I went to sears before I started and picked up a 700ft lb impact gun and it didnt even tickle those ubolt nuts. I sat under there with a breaker bar and a length of black pipe forever turning those things. The shackle bolts I can loosen no problem. Its the bolts themselves I cant get out. The rubber bushings are stuck to them. Maybe i'll try melting the rubber.
Old Feb 1, 2008 | 09:11 PM
tjbeggs's Avatar
tjbeggs
I wasn't joking when I said rattle them for a few minutes with the impact is you have an air source that can keep up. and you already have the RSK. Good deal. Is yours the 3 inch or 5inch?
Old Feb 1, 2008 | 09:18 PM
F0rdF0rever
I have the 3 inch rsk from sky manufacturing. My air source is good. Its a 33 gallon shop compressor. 6.4 scfm
Old Feb 1, 2008 | 10:29 PM
c00nhunterjoe
sears guns arent the best..... and we have some 1 inchers at work that will tear your arm off!
Old Feb 2, 2008 | 10:23 AM
73strokin's Avatar
73strokin
Mabey you should try 80 gallons at 24.3 CFM!
