Starter Solenoid
Old Jan 31, 2008 | 10:00 PM
Tre-E_Ford's Avatar
Tre-E_Ford
Starter Solenoid
Why do starter solenoids go out so much? There is no way that it's always because of vibration and heat. My EB did it only once when i first got it. Just changed my trucks out today and it went out after one short drive. Give this youngin some insight, please?
Old Jan 31, 2008 | 10:17 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
someone may later prove me wrong, but your cable to the starter may not be tight enough, cable may be shorting out on the exhaust or inner fender, guage of cable too small (numerically high) or bad starter. hope this helps!
Old Jan 31, 2008 | 10:22 PM
Tre-E_Ford's Avatar
Tre-E_Ford
the cable is pretty bad, i'll pick one up when i replace the solenoid tomorrow. thanks for the info. Any more ideas.
Old Jan 31, 2008 | 11:15 PM
Mil1ion's Avatar
Mil1ion
There are some inferior relays/solenoid out there made by SE Asian companies
You're always best off buying Motorcraft.
Old Jan 31, 2008 | 11:35 PM
fmc400's Avatar
fmc400
MSEE
I've had problems with solenoids before, too. I had one go bad after only a few months - it wouldn't even click. Had a good ground, voltage on the S wire, everything. Replaced it and no problems since. I also had one stay on once...not good.
Old Feb 1, 2008 | 08:47 PM
73f100shortbed's Avatar
73f100shortbed
I had one that would not allow my truck to shut off. Replaced it and three weeks later that one wouldn't let the truck start. %$#@!@^* foreign parts!
Old Feb 1, 2008 | 09:20 PM
Tre-E_Ford's Avatar
Tre-E_Ford
solved the problem, the ignition switch wire was bad and that other one next to it, forget what it is, got some new connectors and it works fine now all thanks to this forum
SnapClear
Apr 6, 2013 12:46 PM
Tyler Rowe
13
Mar 8, 2013 04:35 AM
Brother Les
15
Jan 23, 2013 10:08 AM
tenforty_2
Jan 1, 2010 12:46 PM
ArtsBest
Electrical Systems/Wiring
Oct 9, 2008 01:20 PM
