GP problem or fuel lift problem?
Old Jan 31, 2008 | 07:39 PM
Catsailor's Avatar
Catsailor
I have a (new to me) '94 IDI Turbo F350. I'm in South Carolina and it is not cold, about 45 degrees at night. If block heater is plugged in the truck starts easily, if not plugged in it it really tough to start. One mechanic says I should add a fuel lift pump - I am thinking that I have GP problem. Have already replace the GP relay but that did not seem to do any good. Am planning to test GP's for resistance and voltage. Any other suggestions?
If there is an old post I should read feel free to point in the right direction, I've searched a bit but then decided to post this.
Thanks
Old Jan 31, 2008 | 09:00 PM
speedrdr's Avatar
speedrdr
does the truck smooth out running after it warms up after a no block heater start? if if does, it may not be more than an air intrusion problem in the return lines. are they still gray? if so probably original and ready for replacement. might look at that before going to the expense of a lift pump.
speedrdr
Old Jan 31, 2008 | 09:08 PM
Catsailor's Avatar
Catsailor
It does seem to smooth out right away and runs great. Engine was rebuilt but no idea if they replaced fuel return lines, will look closer tomorrow. Also, where can I find Beru GP's for this truck - I am really suspicious of the GP's that the previous owner would have used - especially after seeing how the trany rebuild was botched up.
Old Jan 31, 2008 | 09:11 PM
speedrdr's Avatar
speedrdr
car quest here carries them, but don't know if that's true everywhere.
speedrdr
Old Jan 31, 2008 | 10:32 PM
DIRTYSTEVEN's Avatar
DIRTYSTEVEN
Just another thought for you,
I have replaced the plastic fuel lines in the frame rail "feed and return" on both my deisels and it made a huge difference in how both of them started.
Old Feb 1, 2008 | 08:52 AM
arto_wa's Avatar
arto_wa
Your local International Harvester dealer also has the proper glowplugs you need.
Test glowplugs with a 12V test light:
Disconnect all 8 glowplug wires, check each GP for continuity with a test light.
Replace all GP's with no continuity.
Old Feb 1, 2008 | 12:06 PM
Lazy K's Avatar
Lazy K
I would bet on the glow plugs.
Old Feb 2, 2008 | 08:27 AM
Catsailor's Avatar
Catsailor
I found that 4 of the GP's were dead, all Autolite - the 4 good ones are all Beru - so I added in 4 more Beru's. She wants to start better now but still won't catch, she turns over, tries to catch but does not. Also, Wait To Start light still only lights for a few seconds but GP relay continues to tick for about 30 seconds before stopping. Do I wait until ticking stops before turning the engine over? What's next to check and how do I test? GP relay is new, but not the controller.
Old Feb 2, 2008 | 08:02 PM
bigbubba87's Avatar
bigbubba87
if u are waiting for it to stop clicking the cylinders are cooling back down start it right as the wait to start light goes off.
Old Feb 2, 2008 | 11:01 PM
me Mickey C's Avatar
me Mickey C
O'reiley auto parts carries the beru gp's here in mobile
Old Feb 2, 2008 | 11:11 PM
George D.'s Avatar
George D.
try cycling the key a few times as the wait to start light goes ou turn the key off and then back on afew times then try to start it sounds like your gp controller isn't runing the plugs long enough. How long dose the light stay on? Also may be air intrusion still looking for my air intrusion problem truck runs rough when i start it after sitting over night.
Old Feb 6, 2008 | 10:46 PM
casscodiesel's Avatar
casscodiesel
cold star cyliniouds
if it just when you turn it over . my truck did that after i disconnected the cold start . might have gone out. it advances timing for cold starts and does anyone else know if it can cause airleaks??
Old Feb 7, 2008 | 04:03 PM
casscodiesel
What i'm saying is the cold start Revs the motor to run smoothly to give more fuel and also changes timing to deal with your cold block. after the blocks warm it's not needed.
when i removed my cold start plug(after it started to arc from a melted connection) i noticed rough starts in the morning until it started warming up.
43tutor2
Jan 8, 2014 07:25 PM
JDWard
Jan 9, 2013 07:48 AM
surfpunk
Jan 22, 2012 07:31 PM
Glockem45
33
Nov 10, 2008 08:34 PM
webkrawler
Nov 19, 2006 10:41 AM
