License plate light socket.
Old 08-30-2012, 06:24 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,702 Likes on 1,376 Posts
The proper running light circuit will be a brown wire.
Most trucks with a step bumper had two lights, one on each side.
Some of the aftermarket lights only have one wire, so they need a good ground to the bumper for them to work.
Some lights have two wires. One of those will have to be bolted to the bumper or frame to get a ground and make it work.
Old 08-30-2012, 07:19 PM
norts1138's Avatar
norts1138
norts1138 is offline
Ok the light I have only has 1 wire.So by screwing it to the bumper (it has 2 screw with it) if done correctly it should be grounded?And then hook the wire from the light up to the proper(brown) it should light up.
Old 08-30-2012, 07:30 PM
Franklin2's Avatar
Franklin2
Yes. The bumper needs a good connection to the frame, and the frame needs a good connection to the battery negative. From the factory they all have this, but as the trucks get older, modified, and rusty(or cleaned up and well painted) they can sometimes lose these connections.
Onus
13
08-16-2019 10:15 AM
oft
07-11-2016 06:20 AM
52' fordnut
07-15-2015 08:07 AM
polarspeed
13
08-20-2010 03:59 PM
SoloTSi97
1983 - 2012 Ranger & B-Series
10-08-2005 07:28 AM
Quick Reply: License plate light socket.
