EGR Yes or No
Old Jan 31, 2008 | 11:15 AM
bkks744's Avatar
bkks744
EGR Yes or No
Ok everyone with this wonderful EGR debate.......
I have read many posts on this topic and seen it go back and forth between do it and don't do it............ So what is everyones opinion TODAY from those that have tried it. Also I am talking about the 6.0 motor 2005 or newer.
Don't do it?
Unplug it?
Remove it?
Block it???????
What do you think?????????????
Old Jan 31, 2008 | 12:17 PM
doubledee715's Avatar
doubledee715
Don't unplug it. You don't "block" the egr you block the egr cooler. If you want to block the egr cooler but not run custom tunes to disable the egr then you will most likely throw a code whether you weld the egr valve shut or not.
Old Jan 31, 2008 | 12:21 PM
tippmann87's Avatar
tippmann87
Don't do it?
Unplug it?
Remove it?
Block it???????
On the newer 6.0's I would leave in plugged in........
Old Jan 31, 2008 | 12:54 PM
4x4Mark's Avatar
4x4Mark
I'll go against the grain a little here....and my truck seems to run better with EGR enabled:
If you're running close to stock power, I'd address the source of EGR cooler problems focusing on your cooling system - filter and fluid in good shape. The system seems to handle the cooling needs of stock power OK.
If you're pursuing high power, I think you'll stress the EGR cooler even if in good shape, so go ahead and block the EGR at the up-pipe, and disable EGR via your tuner.
Regarding EGR in general, I'm curious if we're seeing a reduction in EGR valve problems with the rollout of ULSD. In theory, it should be better with respect to the valve itself plugging up.
Mark
Old Jan 31, 2008 | 01:08 PM
Joshua0606's Avatar
Joshua0606
Same here. My truck seems to run better with it pluged in.
Old Jan 31, 2008 | 02:59 PM
tex25025's Avatar
tex25025
What are you modding intentions with your truck? If your going to be doing more then a tuner, then you might want to think about blocking then otherwise you will more then likely have problems with it. The other problem with the egr valve is I truly believe that is why we are seeing carbon buildup on turbos, so that's something else that you can have a problem with it, but that is easily prevented though, just an extra nusiance to have to worry about though.
Old Jan 31, 2008 | 03:42 PM
diesel_dan's Avatar
diesel_dan
Mark
Good post. I'm considering a coolant filter myself, just because of this and the engine oil cooler which I hear also can plug up w/ debris in the coolant.
I have heard that disabling the EGR valve w/ just software isn't a sure way to know it's actually closed (I understand gasses can push by the closed valve).
Old Jan 31, 2008 | 03:53 PM
HeavyAssault's Avatar
HeavyAssault
The EGR valve is closed when you shut the truck off. Using a tuner to bypass the PCM operation of the EGR will keep it closed.
I was able to mod my EGR up-pipe and use the SCT to prevent throwing codes. BY far the turbo spools easier and I'm happy, the truck pulls like a mule, runs hard and fast, and I haven't lost ANY mpg's over the whole deal. If you are loooking to prevent EGR cooler problems you need to mod the pipe and get an SCT with a tune to shut off the EGR operation.
It's well worth your time.
Old Jan 31, 2008 | 04:27 PM
ebusa's Avatar
ebusa
Have it turned off with an SCT X3.
Old Feb 1, 2008 | 08:49 AM
rchouser's Avatar
rchouser
I am running Matt's aggressive street economy, any idea if my EGR is on or off? thanks rc
Old Feb 1, 2008 | 08:52 AM
ebusa's Avatar
ebusa
You may have to check with Matt to know for sure. First thing I noticed when I recieved my files with the EGR off is that my truck is much quieter!
Not as much ClackClackClacClack...haha
Gothere
May 13, 2015 01:01 PM
Jaime74656
19
Aug 29, 2013 09:27 AM
Poorboy04
Apr 22, 2013 03:50 PM
sterlingboren
Jan 31, 2013 12:21 PM
kjg26
Exhaust Systems
May 10, 2007 01:40 AM
