egr question
Old Jan 31, 2013 | 10:03 AM
sterlingboren's Avatar
sterlingboren
egr question
Hello everyone
I an new to the ford forum. I bought a 78 f150 with a 400 for a project. I don't know anything about the older stuff so I have been reading alot of the threads on this forum. My question is, the egr valve on my truck has been blocked off by a screw in the vacuum hose. What is the best thing to do with the egr valve. I am not worried about the emissions so I don't mind putting a block off plate in the place of the egr valve.
Old Jan 31, 2013 | 12:21 PM
fmc400's Avatar
fmc400
MSEE
You should hook it back up. Running an EGR engine with the EGR valve disabled can harm the engine (dieseling, pre-detonation) if the carburetion and timing curve are not adjusted to compensate for the altered combustion chemistry.
This topic has been discussed in great length and can be studied using the search function.
My Good 'ol 92
Aug 14, 2011 12:10 PM
WH 6.0
Oct 28, 2010 07:43 PM
lengineering
Jan 30, 2008 10:51 AM
Fluid Power
May 30, 2007 12:32 AM
Galaxie427
Feb 22, 2004 04:39 AM
