Double Overdrive?
Thinking about installing a gear vendors overdrive. This would bring my RPM at 65mph from 2000 RPM now down to 1600 RPM with gear vendors overdrive. I would run this way unloaded only. My question is, will I save fuel by dropping 400 RPMs or will it be the same? Is this engine efficient at 1600 RPM?
I myself have toyed with going with a GearVendor behind my E4OD on my 91 F350 to improve milage however there are two things that stopped me in my tracks.
1,0 Cost. The gear vendor conversion is expensive, even if I did all the work myself I was still looking at ~$4,000 to ~$4,500. Don't forget you need to shorten your driveshaft and re-align the angle on the rear axle to do this right.
2,0 The base E40D is not a very strong tranny to begin with and remember that HP thru the tranny is proportional to the product of RPM and Torque. Since you are going to be using the same Hp to drive as you are driving now, by lowering your RPM you are raising the torque the tranny sees which is going to be even harder on an already weak tranny. Your may have the perfect 2nd overdrive but end up with E4OD trouble. In all fairness you did state in your email that you were planning on running mostly empty (no towing or camper) so my main concern would be Cost. If you got the $$ go for it but be careful on what you expect in cost by future fuel savings.
Again I think a GearVendor would be great choice behind my 93 F250 with the manual ZF5. It would probably push its milage up to the mid 20's and the ZF5 with the DMF clutch can handle the extra Torque. Too bad the cost of the gearvendor installation is so high. I will have to keep my eyes out for a cheap used unit some day.
Lastly be careful, the Gearvendor has a minimum speed you must travel before it engages so don't put you hopes up that you will be doing much double overdrive during city driving. The benefit of the gearvendor really only comes in on the highway.
Sebastian.
Using 3.50 a gallon for fuel cost and driving 10,000 miles,
at 15 MPG you spend 2333.33 for fuel.
at 20 MPG you spend 1750.00 for fuel.
583.33 savings for 10,000 miles
So you will break even in about 45,000 miles if you do the install yourself.
On the plus side, fuel will increase in price so it will pay off sooner.
On the down side, you have a vehicle that is as aerodynamic as a cinder block.
It is heavy and has a large frontal area.
There will be a point that the MPG will stop increasing no matter what you do.
I can't tell you where that point is, there are to many variables.
It is possible to save SOME fuel like this, but as soon as you hit a head wind or hill you will loose any advantage that you had because you are running the truck below the peak torque range.
the way I have mine set up, overdrive is basically used as you propose to use the GV overdrive. At 65 MPH, its turning at ~2000 in 3rd gear (with TC locked), at the same speed in OD, the RPM is just below 1500, not really usable, and generally I will see the same MPG running in 3rd as in 4th at 65 MPH.
Now having said that, I live in BC, and there is not much flat ground on the highway that I drive, if I lived in alberta, than it might be different. My point being, if you spend a lot of time on flat, open road, than you could gain a little, but 20 MPG is always a tough goal, I don't see that very often. Your situation may be different.
Several others as well, but I remember those because they are the most common in our trucks.
It replaces the back cover of the transfer case.
Because it only effects the rear axle. If it engauged while in 4WD, the gearing differance between the front and the overdriven rear, would evantually detstroy one of the R&P's
unloaded about 18-20 MPG
Loaded 13-15 MPG
4.10 gears w/ 35" tires.
E4OD
