Ignition Help
Old Jan 28, 2008 | 03:22 PM
Murray1's Avatar
Murray1
Ignition Help
Hi people I'm new here, my name is Murray and I was hoping you could help me. I have a 1984 F-250. The other day it just quit running on the way to work, It will only run when the key is engaged (starter running too of course), what do you think is happening here.
Many thanks,
Murray
Old Jan 28, 2008 | 03:29 PM
ssidney's Avatar
ssidney
try ignition switch or start selenoid, I believe either could cause your problem
Old Jan 28, 2008 | 04:43 PM
subford's Avatar
subford
Could be the ignition switch but it sounds like it is running off the starter solenoid so the starter solenoid should be fine.
Murray1
Also check your resistance wire from the ignition switch to the ignition coil.
If not those replace the ignition module, make sure it has a blue grommet where the wires go in.
Welcome to FTE.
Old Jan 29, 2008 | 07:01 AM
Murray1's Avatar
Murray1
Does anybody have a picture of the ignition module, I am a poor mechanic, I also do not know where it is located........sorry.
Thank you guys,
Murray1
Old Jan 29, 2008 | 07:22 AM
subford's Avatar
subford
It will be mounted on the driver’s fender. Here are two images.
Note that you need the one with the blue grommet.
Old Jan 29, 2008 | 07:39 AM
Murray1's Avatar
Murray1
Okay I know that one, thank you.
Murray1
Old Jan 29, 2008 | 10:40 AM
Animalistic's Avatar
Animalistic
Check out my post:
https://www.ford-trucks.com/forums/6...l-not-run.html
Even though it is a newer vehicle, I had the same problem. After replacing the
module, it now runs great. And I have the fine folks here to thank for it.
Old Jan 29, 2008 | 11:06 AM
Murray1's Avatar
Murray1
Very helpful
Thank you,
Murray1
