'76 Dash Pad
Old Jan 28, 2008 | 02:20 PM
sedly's Avatar
sedly
'76 Dash Pad
Anyone try to change the color of one these dash pad's.Either paint or die them.Do you think this could be done?
Old Jan 28, 2008 | 02:29 PM
NOCO77's Avatar
NOCO77
Yes, it can be done - dye it, and use good professional quality stuff from an auto paint supply store. Some upholstery shops sell good quality stuff too. They see a lot of heat (UV), so don't mess around with painting - won't last as long. Spray-gun applied stuff is the best, and be sure to prep it right - no left-over armor-all, etc.
Old Jan 28, 2008 | 02:35 PM
sedly's Avatar
sedly
I'm glad to hear that.I found on to re-place mine,it's a light tan color so it shouldn't be to hard to make it black.
Old Jan 28, 2008 | 07:58 PM
greythorn3's Avatar
greythorn3
VHT vynal paint works great.. auto part stores have it, i did mine from tan to black, and its seen 3 summers not garaged and looks good!! wipe it down with thinner good before and repair any cracks with 2 part epoxy.
Ray
http://www.vhtpaint.com/products/sfID1/7/sfID2/25
Old Jan 28, 2008 | 08:02 PM
ranger429's Avatar
ranger429
SEM also makes a good vinyl paint in a spray can.
Old Jan 29, 2008 | 11:47 PM
sedly's Avatar
sedly
Thank's for the info.I'm glad this can be done,it's been dificult to find part's for these old truck's around here.
Old Feb 2, 2008 | 09:31 AM
sedly's Avatar
sedly
I bought the SEM paint.What's the best way to remove the dash pad from the dash?I have the dash out of the truck,but the pad is stuck on.I don't want to risk wrecking it.
Old Feb 2, 2008 | 08:30 PM
four-sixty-power's Avatar
four-sixty-power
Check the tips and tricks thread.....or flip the dash upside down and remove the 11 or 12 nuts from the dashpad studs. You will have to remove the glove box and inst cluster to get to the nuts...unless you are talented with sockets/knuckles/extensions
Old Feb 2, 2008 | 08:34 PM
sedly's Avatar
sedly
Thank's for the tip.I actually got the pad off.I had previously removed all the nut's,the windshield must have been leaking pretty bad.I brought the dash into the house,the next morning there was water on the floor all around it.I think it was just frozen to the steel dash.Anyway it's off,I have to prep it for the dye.
78f250_rls
16
Nov 11, 2024 12:57 PM
sweetlou1
Mar 6, 2013 10:53 AM
motobub
May 17, 2006 09:19 AM
Carlene
Appearance & Dress-Up
Sep 17, 2002 07:02 PM
