1978 - 1996 Big Bronco
Steering Column ???
Old Jan 27, 2008 | 10:03 PM
80351's Avatar
80351
Steering Column ???
After turning the key and starting my 69 Bronco w/tilt, the wheel doesn't always unlock, but is I wiggle it back and forth the lock pin will drop down. It doesn't cause any problems other than you can't turn the wheel.
I've had the steering wheel off and couldn't see anything wrong the pin would come up with the key off turn key back to unlock and it seemed to work fine.
I know there is a gear at the end of the lock pin that turns when you turn the key. Could this gear be off a tooth.
Dave
Old Jan 28, 2008 | 01:29 AM
Surge08's Avatar
Surge08
could be dave. did you replace or repair the column recently?
Old Jan 28, 2008 | 06:31 AM
80351's Avatar
80351
No nothing, but God only knows what the PO (kid) did.
hilti350
6.7L Power Stroke Diesel
Jun 17, 2014 07:45 AM
sbriske
1997 - 2003 F150
Nov 10, 2009 09:21 PM
skippr76
Feb 20, 2008 03:33 AM
werhipp
Mar 14, 2006 05:55 AM
forddytube
Nov 5, 2003 12:21 PM
