Push Button Start
Old Jun 16, 2014 | 08:59 PM
hilti350's Avatar
hilti350
Push Button Start
Hi Everyone I have a 2012 F350 Diesal I want to put in a Push Button start, the problem I have is can I remove the pin that locks the steering wheel. This is the lock and unlock when you turn the key or remove the key. Has anyone tried to do this Please Help
Old Jun 16, 2014 | 10:16 PM
Big-Foot's Avatar
Big-Foot
While I have not had the column apart of the current generation Fords, I have seen the earlier ones, it is a segmented (slotted) steel wheel that is splined to the steering shaft. The segmented wheel could be removed, the segments cut off and then center or hub of the wheel can be reinstalled as it may be needed to provide proper spacing in the column stack.
Alternatively, you could try to remove the pin, but from my recollection, that part of the switch is really not serviceable. You would have to cut it off with an abrasive wheel and in order to do that you'd have to pretty much pull the whole top end of the column apart.
Wondering why I know about this? Most racing organizations don't allow the upper classes of competition vehicles to have locking columns. I've been building race cars and trucks for a lot of years..
Old Jun 17, 2014 | 05:33 AM
hilti350's Avatar
hilti350
Thank You
While I would like to hear from someone who has had a newer model apart I want to thank you BIG FOOT for the fast reply I too have seen the wheel you mentioned. But I heard a rumor that newer models had some kind of pin on the ignition switch itself. In any case Thank you again
Old Jun 17, 2014 | 05:35 AM
hilti350's Avatar
hilti350
Big Foot
Good luck with the new truck
Old Jun 17, 2014 | 06:54 AM
Big-Foot's Avatar
Big-Foot
No problem Hilti350... Somewhere there has got to be pictures of that assembly..
Good luck!
Old Jun 17, 2014 | 07:45 AM
69cj's Avatar
69cj
If it doesn't open then Google 2012 ford f-250 steering colum lock. Quite a few exploded views there.<dir><dir>
</dir></dir>
More images for 2012 ford f250 steering column lock
See if this will open.
bobinyelm
Jun 10, 2019 09:25 PM
katzklaw
Jan 19, 2016 12:40 PM
3Nails
1978 - 1996 Big Bronco
Apr 27, 2011 03:03 PM
OldRed4X4
Jun 21, 2007 11:07 AM
petman
Jul 1, 2003 02:18 PM
