rain storm stall
Old Jan 27, 2008 | 03:22 PM
suppafly14's Avatar
suppafly14
rain storm stall
i have a 1992 f-150 i just got a tune up tone to it new spark plg wire distributer cap but when it rains it still stalls out can someone help?
Old Jan 27, 2008 | 05:08 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from '09 F150 forum.
Old Jan 27, 2008 | 06:20 PM
suppafly14's Avatar
suppafly14
i didnt get anything you sent, could you please resend?
Old Jan 27, 2008 | 06:23 PM
superduty4x4's Avatar
superduty4x4
Water in the distributor. Put a little grease around the edge the cap sits on and see if it helps. I've also heard that water sometimes finds it way in through the little vent in the cap, but I wouldn't try plugging that one off.
Old Jan 28, 2008 | 06:27 AM
Old_Paint's Avatar
Old_Paint
I have a '92 5.0. In it's life, the dizzy cap's been replaced ONCE, along with rotor, wires, and plugs. NEVER in it's life has ANY amount of rain stalled my truck. It's bone stock, with factory snorkel over the rad, yada yada. I have NEVER found water in the dizzy. My guess would be the coil is getting wet, and tracking. This is relatively common on coils that are aging. They'll strike through the insulation to the core iron, and you may not be able to see it unless you park the truck in a dark place with it idling. Get a plant mister bottle, and spray the coil with just plain water and see if it kills the truck. Mine actually arced to the rubber hose to the brake booster (whodathunkit) when it was wet. All this said, if you find any arcing on the coil, it's going south.
Bobbys Big Red Rig
Nov 23, 2013 10:16 PM
1991Broncoky
1978 - 1996 Big Bronco
Jun 26, 2013 06:11 PM
thw1
Jul 1, 2007 07:50 AM
martman429
Aug 9, 2005 12:37 PM
Peltofskin
Apr 2, 2003 05:07 PM
