Broken Dash Mount
Old Jan 27, 2008 | 08:19 AM
ramrod7373's Avatar
ramrod7373
Broken Dash Mount
I thind I have a broken passenger side dash mount. Where is the mount exactly and what is the best way to fix it?
Thanks
Old Jan 27, 2008 | 09:01 AM
crazyF250's Avatar
crazyF250
Should be able to order a bracket from ford, its like a fix it kit because this was a problem with 92-96 if thats what you have. I've seen some on ebay, usually hear about it on the ford lightning sites as the bodies twisted easy because of their torque. Hope this help ya out.
Old Jan 27, 2008 | 12:17 PM
quicklook2's Avatar
quicklook2
you can also use metal screen and epoxy.
Old Jan 27, 2008 | 12:31 PM
nintey4f150's Avatar
nintey4f150
yea i have a 94 and the same one broke just havent had a chance to fix it
Old Jan 27, 2008 | 02:09 PM
lostin90s's Avatar
lostin90s
Also a metal L bracket has been posted on here.Just cut it down . But Ford has a FIx bracket Its not to heavy duty so what ever you decide to use should work fine
Old Jan 27, 2008 | 04:00 PM
66F100Again's Avatar
66F100Again
My son's '95 F250 dash broke on passenger side. Removed kick panel and it's where the lower part of the dash attaches. Looks like it was just thick plastic, and broke near the "ear" where the screw goes. I got a small steel angle bracket at the hardware store ($2), drilled a hole through the plastic dash and through-bolted. Sheet metal screw into metal and it's holding fine.
Old Jan 27, 2008 | 04:53 PM
ACarbone624's Avatar
ACarbone624
SO maybe thats why the passenger side of my dash shakes when I hit bumps and potholes. I'll have to look into that.
Old Jan 27, 2008 | 07:36 PM
jpar19's Avatar
jpar19
I just bought one from Ford. It is part # F4TZ 1504366A and cost $20.30
It is a new bracket and rivets, in case you dont want to fashion your own.
Old Jan 27, 2008 | 07:57 PM
wizzard351's Avatar
wizzard351
mine broke to on the 92
Old Jan 27, 2008 | 10:23 PM
TexasGuy001's Avatar
TexasGuy001
Ford should give that bracket away for free and make it a recall.
Old Jan 27, 2008 | 10:31 PM
ACarbone624
Ain't that the truth!
GuitarJesus
Oct 4, 2014 10:48 PM
dhag911
Sep 13, 2014 11:49 AM
Becky_is_a_66
19
Jul 11, 2014 04:20 PM
wallsy
Australia Chapter
Mar 12, 2014 02:55 AM
BuddyFord
15
Oct 14, 2004 08:04 PM
