Anyone replaced front wheel bearings..??
Old 04-28-2009, 08:29 PM
vwbuge's Avatar
vwbuge
vwbuge is offline
My wife has a '97 Expy and it has around 150k miles. It has some pretty loud sounds from the front as highway speed increases. I haven't had time to pull a wheel yet but I am assuming the wheels bearings will need replaced. I am also going to have the wheels balanced and rotated to see if anything changes.
So, if worse comes to worse, how hard is it to replace the front wheels bearings? I am assuming they need pressed in/out?
Thanks,
Paul
Old 04-28-2009, 09:21 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
is this a 4 x 4? if so, the front hub and bearing are an assembly. you buy the unit and install. it is pre greased. you take off the wheel/ tire. then remove the brake caliper then brake disc. the alxe is held on by a big nut, maybe 34-36 mm. take the nut off and push the axle inward 1 inch. now go to the back of teh hub and remove the 3 bolts attaching the hub/bearing unit to the steering knuckle. they might be 15mm headed bolts and TIGHT. i use a 6 point Craftsman wrench and a 5 pound hammer. The bolts may be loctited in position. You can bu a new hub/ bearing unit and reinstall. most come with new bolts.
Old 04-28-2009, 09:25 PM
steve(ill)'s Avatar
steve(ill)
Old 04-28-2009, 11:08 PM
vwbuge's Avatar
vwbuge
vwbuge is offline
Looks pretty straighforward, just expensive. Thanks for the reply.
MickJaggernaut
12-16-2014 11:21 AM
guessrow
2004 - 2008 F150
01-14-2011 01:47 PM
vwbuge
1997-2006 Expedition & Navigator
05-04-2009 11:36 AM
Paul Dozoretz
1999 to 2016 Super Duty
12-28-2008 07:19 AM
paulpatter
09-02-2006 09:48 AM
Quick Reply: Anyone replaced front wheel bearings..??
