Upper steering collar
Old Jan 25, 2008 | 04:53 PM
64blue's Avatar
64blue
I have a broken upper shift collar, Its the part between the wheel and shift collar. The shifter handle has a flange at the bottom that fits into a metal guide on the back of the upper collar. This metal guide is attached with two small flat head screws. This is the actual part that is broken. Does anyone know the name of this part? can it be bought? Is there a diagram?
Old Jan 25, 2008 | 04:57 PM
Mil1ion's Avatar
Mil1ion
Sounds confusing.
what truck and Trans ?
Old Jan 25, 2008 | 05:02 PM
64blue's Avatar
64blue
1977 4x4 ranger with c6 auto. Its the part between the collar in the picture and the wheel
Old Jan 25, 2008 | 05:10 PM
Mil1ion's Avatar
Mil1ion
I may have to go to the garage to renew my mind
Old Jan 25, 2008 | 05:54 PM
64blue's Avatar
64blue
This switch attaches to the part I need
[/img]
Whats the name of the part that this signal switch is attached to?
Old Jan 26, 2008 | 03:13 AM
Dirt racer's Avatar
Dirt racer
I think it is called a shift collar. I replaced mine in a 75 f100 4x4 about 7 or 8 years ago. I think ford still sold them then. I bet you can still buy them aftermarket. It was aroung $25 back then. I think I just saw one on ebay. When you change it out, you have to take the bottom connector that the wires go for the turn signal switch apart after you write down where all the wires go to in the connector and feed the wires back up the steering column while removing the switch. You do not have to cut any wires. From what I remember that was the worst part of the job
Old Jan 26, 2008 | 01:41 PM
Mil1ion's Avatar
Mil1ion
Naw he is talking about the Upper flange.
The shift collar is what I posted a photo of in the above post.
Blue, I'll go to the garage for you
EDIT:
He means this:
and
This is the Tilt column version
Old Jan 26, 2008 | 07:17 PM
64blue's Avatar
64blue
Yep, thats it. I was able to purchase one from LMC. I hope it has the part I need. The actual upper column part isnt broken, but there is a small metal guide screwed to the back that is broken. Im not sure if its a guide for the shift lock or the gear indicator.
Old Jan 31, 2008 | 06:57 PM
64blue's Avatar
64blue
This is my upper column picture
[/img]
This is the rear of my new upper steering column. There is a samll brass looking slide that screws into this hole and curves across to the other hole. I also need this part. Anyone know how to find it, or even know the name of it?
Old Jan 31, 2008 | 07:34 PM
Mil1ion's Avatar
Mil1ion
You shuuld see it here
7A216
Old Jan 31, 2008 | 08:22 PM
64blue's Avatar
64blue
Thanks for the info. I found one on a site called http://www.squarebirds.org/index.htm
This part is called a "detent plate"
stockjay
15
Jun 8, 2019 10:38 AM
abyars111
15
Aug 22, 2013 02:56 PM
Little Wolf
Nov 28, 2011 04:04 AM
jdb1982
Aug 23, 2005 05:09 PM
jody
Sep 16, 1999 06:39 AM
