D2TEAA Head question
Old Jan 23, 2008 | 08:44 PM
mlevario99's Avatar
mlevario99
Exclamation D2TEAA Head question
I have a set of D2TEAA heads from a 76 FE390 F100 truck, I was removing the valves and I notice that on top of each of the exahust chambers there is a screw plug, and inside the chamber coming form that screw plug is a pipe about 1/4" in diameter and about 2 inches long, what are those pipes, and can I just remove them and leave the screw plug in place?
Thanks
Old Jan 23, 2008 | 09:26 PM
Redmanbob's Avatar
Redmanbob
It's smog stuff. I did that on my 66 F100's C6TEG's and havent had any issues.. I do see some bubbling around the base of the plug when it's first warming up but it clears up and hasn't been an issue as far as I can tell. Thing runs like a top "in circles all over the road" LOL
Old Jan 29, 2008 | 06:27 PM
JesusRocks's Avatar
JesusRocks
yeah it's just the thermactor stuff for emissions control as far as i know. You should be fine without it. should run better too
Old Jan 30, 2008 | 07:40 AM
mlevario99's Avatar
mlevario99
Ok, thanks for the info. More questions, I need to install new valves on the heads, could I use the CJ valves, and would it be worth it. Can the machine shop install them with out a problem and where can buy them, which ones do you guys recomend.
Thanks
Old Jan 30, 2008 | 08:19 AM
Redmanbob's Avatar
Redmanbob
wouldn't bother unless you plan on hitting the strip with it. Under normal operating conditions you wouldn't notice a thing
Old Jan 30, 2008 | 08:27 AM
mlevario99's Avatar
mlevario99
Thanks Redmanbob, but you will consider porting the heads, correct.
Old Jan 30, 2008 | 08:48 AM
Redmanbob's Avatar
Redmanbob
I would consider doing a lot of reading and studying other picts before you attempt it. Can be done but "as a novice" I can say it's not for the novice.. your better off just sanding out the casting slag and calling it a day.... thye time it takes to do it right I now see why guys make 5-600 for a set of heads...easy 3-4 days work to get it right.
Old Jan 30, 2008 | 10:48 AM
mlevario99's Avatar
mlevario99
Redmanbob, I was planning on using the intake gasket to open the intake port on the heads, and sanding the casting slag. By the way I am planning on buying a Edelbrock Performance RPM intake.
Old Mar 31, 2009 | 11:34 PM
B13 man's Avatar
B13 man
Question help us with som head casting numbers
Thanks
help us with some head casting numbers to see if the heads are matching
tbirdscott
Sep 15, 2015 11:13 PM
OffshoreDiver
Jul 13, 2012 05:35 PM
fordman400
Aug 19, 2010 08:29 AM
mudracin74
13
Jun 28, 2004 03:08 PM
dieingford
Jun 26, 2004 04:46 AM
