Gauge Questions
Old Jan 23, 2008 | 08:13 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Gauge Questions
All right boys I talked my dad into getting gauges tonight. Another step closer to getting the Dp tuner
My question is this I want to get a 4 gauge pod holder instead of the 3 pods but right now I am only buying 3 gauges. Is there a way to fill the 4 hole for right now while I am not using it. Also these are the gauges I want to get are these good accurate gauges. I am going 35 Boost, Pyro, and trans. http://www.puredieselpower.com/catal...-22_25_59.html
Thanks
Nick
Old Jan 23, 2008 | 08:26 PM
fxstbchopper's Avatar
fxstbchopper
They make a blank that you can put in the 4th hole till you are ready to use it. Here is a link.
http://prosportgauges.com/52mm-switch-panel-pod-dash-gauge-blank.aspx
Old Jan 23, 2008 | 08:28 PM
weekendwarriorfsw32
Master of Strokes
Thats exactly what I was looking for. Thanks dude
Old Jan 23, 2008 | 08:51 PM
weekendwarriorfsw32
Master of Strokes
Also will this gauge pod fit my Excursion. I think the super duty and the Excursion A pillar is the same right http://www.puredieselpower.com/catal...308-p-177.html
Thanks
Old Jan 23, 2008 | 08:54 PM
fxstbchopper
Yes the A pillar is the same for the super duty the the X's. So that one should work fine.
Old Jan 23, 2008 | 09:13 PM
white Buffalo's Avatar
white Buffalo
DiPricol are great guages, your Dad will love them...
Old Jan 23, 2008 | 09:20 PM
weekendwarriorfsw32
Master of Strokes
Thanks guys I cant wait to get them. I will let you know how they go
Nick
Old Jan 23, 2008 | 09:47 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I just installed a set of the Optix gauges in my work truck, only convincing dad that we needed them because sometimes we pull over 20K pounds and that's forsure working the truck. I love them, and really want to upgrade to the optix gauges in My truck!
Old Jan 23, 2008 | 10:16 PM
weekendwarriorfsw32
Master of Strokes
If I rember right there was a great web-sight that showed all the install steps. Does any body rember what it was
Thanks
Old Jan 23, 2008 | 10:26 PM
PowerstrokeJunkie
w w w . d i e s e l m a n o r . c o m
Old Jan 23, 2008 | 10:36 PM
weekendwarriorfsw32
Master of Strokes
Thats it Thanks Chris
Old Jan 23, 2008 | 10:46 PM
weekendwarriorfsw32
Master of Strokes
Also whats the best way to install the Egt probe. Tap it or use a c clamp
Thanks
Old Jan 23, 2008 | 11:19 PM
ron01sd's Avatar
ron01sd
go with the four gauge setup and leave the fourth one empty till the DP comes in and fill the fourth hole with the DP's new f5 gauge switch.
Old Jan 24, 2008 | 01:04 AM
bandlgeorge's Avatar
bandlgeorge
Nick-Go with the Dipricol's, I love them. Only one note on the wiring that you may have seen in my recent posts. Make sure you combine the ignition wires together and run them to ignition and then the illumination wires together to your headlight switch. Lastly, connect all of your grounds together to a good ground. Should see my pics for grounding location. See below.
As for the fourth hole in the pod:
Just tell your dad it's easier to install now rather than later. That's the truth actually. You will have to be skilled at fishing to get the tuner wire up, or unsnap your pillar from the post to gain access, creating all the more opportunity to mess it up.
Grounding location I used (as viewed from afar)
Close up (see the ground on the left with the yellow round connector?)
Dash light illumination power from afar
and close up (notice the red wire-gauge wire that is spliced to the illumination wire-blue with red stripe)
Lastly, here's the final product. I love hte look of the Dipricols. Clean and sharp.
Kris had a good spot to tap for ignition power that is also in that other thread. It is the #8 post in this thread:
https://www.ford-trucks.com/forums/6...r-problem.html
Drilling for the EGT was easy. Slo and steady is the way to go and I used a flexible magnetic tool to clean out the pipe. I like knowing that mine is actually tapped into the exhaust, but I'm sure clamp is fine as well. I think I've heard of those coming loose ocassionally.
Check Brian at www.dieselpowerproducts.com. He pre-painted my pod for me and threw in the tap for free, although I did buy two sets. The pod painting was standard practice for him though. Think that my 4 gauge pod with the three Dipricols was $397 after WA tax and free shipping.
Most of all-HAVE FUN!!!
Old Jan 24, 2008 | 08:50 AM
AustinS's Avatar
AustinS
Tap and drill the manifold for the probe. It's less likely to get hit when working under the hood. I mounted mine in the up pipe with the clamp and it's been fine for 6 yrs. now, but if I to do it over it would install it in the manifold.
When my up pipes donuts leak again, I'll do the new bellows ones and move the probe to the manifold. Use a little bearing grease on the bit and go slow and easy, cleaning and regreasing before you penetrate through and it keeps the shavings manageable. I also magnetized the bit before I started.
Austin
