5spd
Old Jan 21, 2008 | 10:58 AM
Redneck1465's Avatar
Redneck1465
5spd
I am looking to put a 5spd manual trans into my 85 F150 and I was wondering if anyone knew what transmissions came in the 87-96 Trucks so that I could try to find one. I am looking for a relatively strong trans cause I am going to need it to haul with. I want the 5spd for the extra gear for fuel economy. Thanks in advance.
Old Jan 21, 2008 | 11:00 AM
Moore558's Avatar
Moore558
Try and get a ZF 5 speed transmission if your going to be hauling a lot.
Old Jan 21, 2008 | 11:07 AM
Redneck1465
I forgot to mention its two wheel drive so I need a 5spd for two wheel not four. Not really sure if it makes a difference but I thought I would throw it out there.
Old Jan 21, 2008 | 11:21 AM
Moore558's Avatar
Moore558
The ZF came in 2wd and 4wd versions, but I don't think the tailshaft housings were the same between the two (someone correct me if I'm wrong). It's just a matter of finding a 3/4 ton or 1 ton 2wd that has the transmission you need.
What engine does your truck have?
Old Jan 21, 2008 | 11:52 AM
andym's Avatar
andym
Yep, you definitely want the ZF. It was available in 2wd versions with the small bell pattern.
Old Jan 21, 2008 | 12:59 PM
Redneck1465
I have a 351W. (5.8L) So I basically need to find an F250 or F350 with a stick? Can I use a trans out of a deisel or is that a different bellhousing? Do I need to change the flywheel as well?
Old Jan 21, 2008 | 01:04 PM
Moore558's Avatar
Moore558
I believe diesel engines used a different housing than the windsor blocks. You would definetely need the right a new flywheel for a 5.8 that can be used with a ZF.
Old Jan 21, 2008 | 01:07 PM
Redneck1465
Did most of the ZF tranmissions come in trucks with the 5.8 or were they mostly in stuff with desiels or the 460s?
Old Jan 21, 2008 | 01:17 PM
RC Dan's Avatar
RC Dan
ZF trannys came in trucks with the 4.9 and 5.8.
The 5.0 trucks usually had a M5OD, which most would say isn't suited for a lot of heavy loads or towing.
Old Jan 21, 2008 | 01:55 PM
andym's Avatar
andym
Most came with diesels or 460s, but there were plenty made with 300s and 351s. You shouldn't have a problem finding one, but it will cost you close to $1000 for a known good tranny. Your best bet might be to find a parts truck with the tranny in it.
Old Jan 21, 2008 | 02:13 PM
84-250's Avatar
84-250
Redneck: PM if you live close to Ohio. I have everything to convert.
Old Jan 21, 2008 | 04:01 PM
godblessmud's Avatar
godblessmud
That truck came with the M5OD (mazda) 5 speed but try to find a ZFHD for your truck cause the spazda trannys are weak
Old Jan 21, 2008 | 04:14 PM
84-250's Avatar
84-250
godblessmud:which truck are you talking about? There are only two truck mentioned, his 85 f150 and my 84 f250, and neither was available with a 5 speed, let alone a mazda.
Old Jan 21, 2008 | 04:23 PM
godblessmud
Sorry misread 85 as 95, disregard my previous post
Old Jan 21, 2008 | 10:35 PM
Redneck1465
Can the other transmissions be built to handle some power?
