5spd
Old Jan 21, 2008 | 10:42 PM
godblessmud's Avatar
godblessmud
which one?
Old Jan 21, 2008 | 11:16 PM
Redneck1465's Avatar
Redneck1465
The M5OD transmission
Old Jan 21, 2008 | 11:39 PM
godblessmud
Its really not worth it to try to build it up, there is no support for such a project and it would be much simpler/cheaper/reliable to find a ZF that matches your engine
Old Jan 23, 2008 | 11:14 AM
nighthawk285's Avatar
nighthawk285
I swapped a ZF into my '87 F150 351W that had an automatic AOD transmission in it. Would do it a million times over again too. The ZF is a tough transmission, when I got mine from the junkyard (for $500) I took it to a trans shop just to have 'em check it and maybe replace a bearing here and there, and when they opened it up, about 2 gallons of water came out of it. With a lot of cleanup, still using the original gears and synchros (although the 2nd gear synch is headed out) and new bearings and brass bushings, I was good to go. Put 12,000 miles on it so far with no problems at all.
Old Feb 10, 2008 | 06:31 PM
deanco_112's Avatar
deanco_112
I'm a new member,deanco_112 with a question,can i bolt a 96 3.0 5spd to a 94 4.0?both are V6.
Old Feb 10, 2008 | 10:16 PM
nighthawk285
as long as the bellhousing pattern is the same, it'll be a bolt-in swap, otherwise, you might need an adapter plate
Yeehaw1
Oct 2, 2012 06:12 AM
palmer1155
Feb 18, 2009 06:18 AM
73cntry
Jul 11, 2008 11:22 PM
DAJF150
Jan 11, 2006 07:45 PM
Mr. Finch
24
Mar 11, 2005 06:39 AM
