smooth idle?????
Old Mar 30, 2002 | 11:29 AM
TCTOOL's Avatar
TCTOOL
smooth idle?????
I need help with my '76 460, 51,000 miles. I have new Holley 750, plugs, cap, rotor, wires, vacuum lines, pvc. I had the mix and rpm set by a pro, it runs great but I still have a rough idle. Haven't had the timing set and have a hard time finding anyone that works on a carb.
Any ideas???
Old Mar 30, 2002 | 10:10 PM
83f2504x4's Avatar
83f2504x4
smooth idle?????
Factory cam? if so definitely check your timing... if you werent going to do it yourself, it would at least be a good idea to make sure that was the problem first. loosen the bolt at the base of the distributor and then slowly turn it clockwise (this will advance it) and see if it smooths out. if advancing makes it worse, then just turn it counter-clockwise till it smooths out. with the factory compression and ignition curve, its pretty hard to screw up on ignition timing when going by ear. advance till it idles the highest and smoothest and then back it off just a tad. if ever you get "pinging" noises under load or sputtering at higher rpms when you arent giving it much gas, then back it off a bit till it stops.
Old Mar 31, 2002 | 05:18 PM
killer4x4's Avatar
killer4x4
smooth idle?????
Also can put in a electric fuel pump which is smoother than a factory mechanical.
Old Apr 1, 2002 | 05:02 PM
79F2504x4's Avatar
79F2504x4
smooth idle?????
400inatruck
Jul 30, 2011 07:38 PM
neb0244
18
Sep 2, 2010 04:06 PM
cjf5150
Feb 5, 2007 07:42 PM
GSchretter
Oct 6, 2004 02:06 PM
boond0cksaint
May 17, 2004 04:18 AM
