302 w/idle problems
Old Jul 25, 2010 | 03:04 PM
neb0244's Avatar
neb0244
302 w/idle problems
I have a 91 F150 with a 302 that I just purchased. It is a 5 speed. The check engine light was on. Checked code and found TP sensor problem and fixed it. Someone had advanced the timing to 20 degres. Set timing to 11 degres and had to replace Idle Air Control Valve. It was running very well, no codes but now the idle is jumping all around. Twice it has jumped to 3000 RPMs while waiting for train or light to change. The idle is hanging at 2500 when changing gears and it surges up and down. Any ideas please help.
Old Jul 25, 2010 | 03:42 PM
302flareside1992's Avatar
302flareside1992
what was the problem with the TP sensor? the sensor itself might be bad.
Old Jul 25, 2010 | 08:14 PM
neb0244's Avatar
neb0244
One of the 3 connectors in the plug pushed out and was not making a good connecton. That has been fixed.
Old Jul 25, 2010 | 09:26 PM
Rudiak's Avatar
Rudiak
Subscribing. I have a 92 f150 302 m5 with 190k miles. I have had the same problem off and on for the last 100k miles. I have changed the tps, iac valve, throttle body, checked for vaccum leaks, lubed throttle cable. It never throws any codes. I ran out of ideas a long time ago. Right now it seems to be ok but it will come back it always does.
Old Jul 26, 2010 | 04:29 PM
neb0244's Avatar
neb0244
This morning the truck ran great but then on the way home this afternoon it started doing it again. The check engine light came on for about 30 sec. then went back off.
Old Aug 31, 2010 | 07:40 PM
failte's Avatar
failte
I have a 1990 F250 / 302 and its been doing the same thing. CEL has been on for a while. I have changed the IAC and checked cables. I'm sure its not something sticking now because when it goes to 2500ish RPM at idle, if you quickly turn the key to OFF then immediately back ON (so fast that engine's own rotation starts it back up) the idle comes back to normal. But NOW, the idle is constantly messing up to the low side also. It will go down to 400 RPM as well. Then it started bogging down as soon as you put a load on the engine, even at 700 ish RPM, unless you get it to approx 1500 RPM first. Then it will drive normally except the occasional roars to 2500RPM's when you shift gears. However, it started just quitting once it gets hot and you have shut the engine down. In fact, I just took the bus home. Drove it and it ran OK. 20 minutes after shutting it down, nothing at all. Have pulled a spark plug and showing no spark. This is the second time this has happened this way. I changed the coil, the ignition control module. Nothing. Mine seems to be heat related. No idea what to check next, and neither does the nearby professional mechanic.
Old Sep 1, 2010 | 02:58 AM
TexasGuy001's Avatar
TexasGuy001
If it has an erratic or surging idle then I would think it could have a vacuum leak. Its something to check and could be a cheap fix.
Old Sep 1, 2010 | 07:51 AM
rla2005's Avatar
rla2005
Classic symptoms of a bad PIP sensor in the distributor. The sensor can be changed but it is tedious work. Do not be tempted to purchase a rebuilt distributor. Most of those have the same problem. The best bet is a new replacement distributor.
Old Sep 1, 2010 | 04:22 PM
SMF Speed&Custom's Avatar
SMF Speed&Custom
Possibly the EGR valve on the passenger front side... $106 for a new one at Auto Zone though. I am having a similar problem and changed the IAC valve and cleaned the throttle body, etc. It went away for 2 weeks or so and now started back up but a little different. EGR valves will eventually get dirty and build up with carbon I believe so I would pull yours off and take a look at it.
Old Sep 1, 2010 | 06:02 PM
rla2005's Avatar
rla2005
So how would a faulty EGR valve cause a no spark condition?
Old Sep 1, 2010 | 06:40 PM
Rudiak's Avatar
Rudiak
He is probably talking about the high idle problem in the op.
Old Sep 1, 2010 | 08:31 PM
SMF Speed&Custom
I didn't say it was causing a no spark condition. I read his first couple of posts and put my answer down. If he later said something about him narrowing it down to losing spark then that is a different story.
Old Sep 1, 2010 | 10:35 PM
rla2005's Avatar
rla2005
Ok, I agree there are two issues going on here. First is the high idle. The second is the no start condition in Post#6.
I will try to stay on topic here!
Old Sep 1, 2010 | 11:29 PM
SMF Speed&Custom
LOL no problem. You caught the question I missed and visa versa. It happens. I re-read my post and I sounded like an *** but didn't mean it like that just to let you know. If he is losing spark, how about the ignition module on the drivers side firewall or fender towards the firewall? I am not sure that is the correct name for it but it's the silver box with the louvers in it. I hear these are problematic on some of these Fords because they are not mounted in the front near the radiator like the newer models are, therefor they heat up and eventually go out (that's electronics for you).
Old Sep 2, 2010 | 12:05 AM
75Three90's Avatar
75Three90
are you getting power to your vaccume control modual if not its a fusable like ive hd this happen before
