EGT Guage Setup
Old Jan 20, 2008 | 08:19 AM
jroy's Avatar
jroy
Question EGT Guage Setup
I am installing a dp tuner and need recomendation for an EGT set up. What's better to go with : in the pipe or in the manifold (pre or post turbo?) ? And where would the thermocouple be easily installed for either choice ? Thanks.
Old Jan 20, 2008 | 08:26 AM
ron's power stroke's Avatar
ron's power stroke
i put mine in the driver side manifold..some put it in the driver side up pipe...its best to have it before the turbo
Old Jan 20, 2008 | 09:18 AM
Pocket's Avatar
Pocket
Pre-turbo. Always pre-turbo.
Look underneath the truck at the rear of the driver's side exhaust manifold. From there you can either drill and tap the manifold, or you can drill and clamp to the uppipe just above the manifold. Either location will work fine, and it all depends on your own personal preference and/or tools available. If you have a tap and die set, might as well go into the manifold.
Old Jan 20, 2008 | 09:52 AM
muddingmcdude's Avatar
muddingmcdude
i got a question whats the max egts for this motor i know my idi was 1250
Old Jan 20, 2008 | 09:55 AM
fxstbchopper's Avatar
fxstbchopper
It is the same about 1200 maybe more but not for very long periods time.
Old Jan 20, 2008 | 10:19 AM
Izzy351's Avatar
Izzy351
You can spike it way hotter than the ~1220* melting point of aluminum because it takes a while for the heat to soak in and start melting a piston. DON'T keep it there long, and staying below ~1220* is always smart. However, I have spiked mine hotter than that while in the "heat" of battle, but only long enough to show the Dodge or Chebby who's boss...
Old Jan 20, 2008 | 12:08 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
You can let the EGT climb as high as you want, 1500+, however on stock injectors it will take a long time to get there if you even can. I hit 1375 doing a burnout once, and it was fine because about 5 seconds later i was out of it idling. If you are towing you won't want anything over 1250 sustained, however you can sustain that temperature for as long as you want. I put stage one injectors and DP tuner in my 95 dump truck, and i installed gauges. Hauling 5000 pounds of salt it easily bent the EGT past 1500* going up a hill and i wasnt worried because that was for a few seconds.
Old Jan 21, 2008 | 08:11 PM
jroy's Avatar
jroy
ok, i got an "Auto Meter" brand egt meter from Checker Auto Parts and installed it in the manifold as instructed. $155.00 for the meter. i guess that and my newly installed dp tuner will get me by for now. thanks for everyones help/suggestions.
