1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2001 250 super duty
Old 01-19-2008, 09:42 PM
crazymut's Avatar
crazymut
crazymut is offline
Question 2001 250 super duty
Wondering what the consenses is on upgrade headlights? My stock ones just are not bright enough.
Old 01-19-2008, 10:11 PM
Benny2002's Avatar
Benny2002
Benny2002 is offline
You can go with the 02-03 Style composite with sylverstar bulbs which are plenty bright, especially with the highbeam mod. Search BRIGHTBOX
Or you can go with the 05 model or the harley davidson edition which look cooler but i think are as bright.
The older style are cheaper and i think you can find both of them on EBAY ,bulbs at autozone, anything is better than those cloudy things youve probably got. Whole shootin match out the door 200-400ish on the wallet
Old 01-19-2008, 10:54 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Agree with Benny on this one. Go with the '02-'04 clear style...even if you keep the OEM bulbs. But...a nice upgrade to that are the Sylvania.
Part #: 9007SU
Description: Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
biz
Old 01-19-2008, 11:59 PM
crazymut's Avatar
crazymut
crazymut is offline
Do the 02-04 clear styles mount up the same as the 01?
Old 01-20-2008, 05:38 AM
INF GUY's Avatar
INF GUY
INF GUY is offline
guys where can i get stock 02 headlight assemblies???
Old 01-20-2008, 03:24 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Absolutely. A direct bolt-on.
If you want totally new OEM, then you might try a FTE sponsor DirectFordParts. Or...a good alternative is eBay.
biz
Old 01-20-2008, 03:54 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
If you want a little more after all that you can do a harness upgrade to get as much voltage as possible to the bulbs. They only use like 18Ga wire so there is quite a loss in voltage. My Intrepid was wired the same way, 18Ga from the battery, to the relay box, to the fuse box, to the headlight switch, to the dimmer switch, and finally to the bulbs. I measured voltage at the bulbs with the bulbs in and headlights on and it was only 10.5V when the battery measured 12.7V. Also light output goes down at the power of 3.34 or something like that with voltage. I put relays in last weekend for high, low, and fogs and it was a pretty good improvement.
Old 01-20-2008, 04:17 PM
dew the thunder's Avatar
dew the thunder
dew the thunder is offline
I got my 02-04 style lights and a set of clear corners for 130 plus shipping off eBay. You can also get those style lights from TYC.
Old 01-25-2008, 06:50 PM
crazymut's Avatar
crazymut
crazymut is offline
Are the 9007su bulbs the blue ones? They are bright but I hate looking at them when they are coming at me. I am looking for a light that is bright but that will not tick people off as they are driving towards me.
Old 01-25-2008, 09:10 PM
cartmanea's Avatar
cartmanea
You just have to be sure not to aim them too high, thats the biggest problem with most headlights. People raise them up so the low beams are darn near high beam height and then the high beams are almost off the road high. The low beams in my Intrepid are so bad I lower them way down and run high beams. They still suck, but are better at least and I never get flashed by oncoming traffic.
Old 02-07-2008, 06:37 PM
crazymut's Avatar
crazymut
crazymut is offline
does anyone have the projector style lights, how do they perform?
Old 02-07-2008, 10:04 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Not sure myself...but...it does say, "Whitest" in the description.
Part #: 9007SU
biz
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: 2001 250 super duty
