DP Tuner Install
Old Jan 19, 2008 | 11:32 AM
jroy's Avatar
jroy
DP Tuner Install
Just got my setup from Jody. He sent installation instructions along with the programmer and they are pretty straight forward, but I was wondering if anyone has any "tips" or suggestions that come from experience. My truck is a 2001 F250, 7.3, six speed manual. Thanks.
Old Jan 19, 2008 | 11:42 AM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
i think Jody covered everything well in the instructions, if you follow them and clean the silicone of the contacts you will be perfectly fine. i know 6sp can be a pain while removing the PCM, and especially the plastic cover on it.
so make sure take you time remove pcm bolt under the hood and dont force it if you unsure.
Welcome to Permagrin Club...
you will be ok,
Old Jan 19, 2008 | 01:52 PM
jroy's Avatar
jroy
ok then , sounds good . I will be sure to be patient. I'll post after install. thanks again !
Old Jan 19, 2008 | 01:59 PM
PETE'S_6.0PSD
good luck, and berofe you put the pedal to the metal make sure worm up the motor , than tell us what you think about you new found power.....
Old Jan 19, 2008 | 04:02 PM
badger2196's Avatar
badger2196
I have a 6spd manual too, and getting the PCM box out is almost impossible without removing the 2 mounting bolts inside the footwell (the clutch pedal gets in the way), but Jody's instruction mentions that anyway.
Also, don't be tempted to just plug in the connector on the firewall to test it (like I did) without bolting it up - it just won't work without being fully bolted up. It's a pain to get that bolt in and out repeatedly if you haven't quite cleaned the connectors properly (I had to dismantle the whole thing and redo it because of this) but once it's all done it's well worth the effort.
Main thing - take your time and clean that PCM connector properly!!
BTW, what tunes did you get?
Old Jan 19, 2008 | 04:48 PM
Jzinkiewicz's Avatar
Jzinkiewicz
go to this site. video
http://www.dieselmovies.com/view_vid...163467c9dae521
Old Jan 19, 2008 | 04:53 PM
sflem849's Avatar
sflem849
It is easy. Like Badger said, don't mess around on the cleaning. I may have cleaned mine a little too much, but I used plenty of duct tape, too! Go to Jody's website and print out or at least look at the pics of the cleaned contacts. ITP diesel also has them on their website. It is simple to do. It was way easier than any other mod I did to my truck. Cleaning the contacts well takes longer than bolting or unbolting the PCM (in an auto). Good luck and have fun. I didn't see where you are from, but I hope the roads are dry. Then again smokey doughnuts are fun, too!!!
Welcome
kyle1979ford
Apr 1, 2012 12:17 AM
john fin
Jul 11, 2011 12:19 PM
arrowheadfred
25
Nov 23, 2010 04:47 PM
teppler
Feb 10, 2010 01:57 PM
region18
Apr 30, 2005 01:43 PM
