Engine installation
Old Jul 10, 2011 | 03:30 PM
john fin's Avatar
john fin
Engine installation
I would like to install my 239 flathead in my truck without the tranny attached. Is it a pain to attach the tranny to the engine from under the truck.
Old Jul 10, 2011 | 04:38 PM
r_reed's Avatar
r_reed
i believe the tranny goes in/out through the cab floor. when you take the transmission cover off, there's quite a lot of room to remove it. i have my seat out now, don't know if it needs to come out, but would make it simpler.
Old Jul 10, 2011 | 04:43 PM
tinman52's Avatar
tinman52
Welder User
Easiest way for me is to install trans first, support with a jack, then install engine. Or install as one unit.
Old Jul 10, 2011 | 06:04 PM
bobj49f2's Avatar
bobj49f2
I pulled my transmission out of my panel truck last summer through the floor opening. I removed both seats just to have extra room, no big deal. I lifted it out myself. Installing the engine without the transmission itself won't be a big problem but you will have to support the back of the engine because it's supported through the transmission. I just blocked up my engine when I pulled the transmission.
Old Jul 10, 2011 | 07:05 PM
ALBUQ F-1's Avatar
ALBUQ F-1
+1... Especially with the big 4-sp. If your hood is off, and radiator out, it will drop in easily with the engine level. Make sure your clutch disc is centered properly. Hint: do your belts before you put it in, it's 100x easier.
ALBUQ F-1's Avatar
ALBUQ F-1
double post... sorry!
Old Jul 11, 2011 | 07:23 AM
john fin's Avatar
john fin
belts
Why belts first, I dont understand.
Old Jul 11, 2011 | 09:40 AM
bobj49f2's Avatar
bobj49f2
I'm assuming he's referring to the fan belts.
Old Jul 11, 2011 | 12:19 PM
john fin's Avatar
john fin
fan belts
Why is that a pain when the engine is in the truck?
phillips91
28
Aug 21, 2015 08:15 PM
lpdcjr
Aug 19, 2014 08:19 PM
Holehawgg
25
May 5, 2014 11:00 PM
usuallybowtie
Oct 10, 2013 10:56 AM
Jonrarick
16
Sep 20, 2013 10:34 PM
