Need Help. Oil Pan Drain Plug/Bolt Stuck.
Old Jan 18, 2008 | 05:24 PM
IcemanV8's Avatar
IcemanV8
Ok, I just changed the oil, again, on my truck. Went to tighten the oil pan bolt up, and it never even got halfway tight. No resistance. Well... I kept turning and turning to make sure. There was no resistance. So, I get it to the 'tightest' spot (probably 5 lbs/ft, lol), and drive it down the road and back and park it to see if it's gonna leak (duh). After I park it, I go inside, come back out and see a tiny puddle of oil. It looked darker than I thought the new oil should, so I wiped it up to eliminate any confusion, went back inside (actually was painting a room inside), and came back out in 10 minutes only to see another oil puddle. (4 inches wide).
So, I get my 5 quart jug of Castrol GTX 10w-30 (empty now) and put it under the plug, and start to take the plug out. I was going to go ahead and capture my oil because I was going to go buy a new drain plug, and would have to take it out, anyways. I start turning it... and turning it... and turning it. The damn thing won't tighten OR loosen enough to come out. I just keep turning it (to take it out), and it never comes out.
WTF do I need to do? It got dark really fast during all of this, and my 250w/500w halogen light is at my mamaw's house. I'll probably just let it leak out in the jug overnight, but has this happened to anyone else? I put some vice grips on it and pulled it out as I turned it to take it out, and it still isn't doing any good. I'll try that again, harder, tomorrow... but has anyone else had this happen?
Old Jan 19, 2008 | 05:52 PM
MisterDave2's Avatar
MisterDave2
Needless to say something is stripped out. Hopefully your fixed up by now. But if not A number of years ago I helped my friend do a job like this, there was a whole kit with a tap and a new plug. Wasn't as easy as the package inferred, but ity did the job. For how long it's good is another point. Good Luck!
kr98664
15
Sep 27, 2016 01:21 PM
Nastynick
Sep 2, 2016 06:54 PM
KJNDIVER
61
Jun 2, 2016 08:33 AM
2civicrr
6.7L Power Stroke Diesel
22
Dec 14, 2015 09:31 AM
tom6433
Oct 22, 2014 11:38 AM
