Just need to vent a little......
Short Version:
Geez, you can't even trust the dealer to get a oil change right.
Long Version:
So.....story starts with me filling up my DEF tank for the first time last night. I let it run down to right about 130 miles to go. It took almost both containers to fill it. Parked the truck for the night.
This morning, I'm too lazy to get up to fish but I'm up.... Figure, I'll take advantage of the 'Free Oil Change' coupon from the my Ford Owner website. Little early on the mileage (5989 miles) but don't want to run into Christmas - it will be too busy. Get down to my local Ford store where I bought the truck. (Although I've handled most of the periodic maintenance, I've used this dealer on my 7.3 & 6.0 for years for 'big work'.) Check in at the 'Quicklane' counter. Tell them not to rotate the tires or check air pressure since I just did it. I wait for the truck to be done.
Done in a reasonable amount of time. Funny thing is, service writer tells me that they topped off the DEF. I say, "No way that happened. I put almost 5 gallons in last night. The tank only holds 5 gallons". Service guy gives me some lame answer that he must have topped it off. I drive home but wonder if things were done right. It lists the air pressure & tire rotation but they weren't done. That is fine as I told them not to do it. It also lists 2 jugs of DEF.....ah no, that didn't happen. Figure whatever.
What gets me is the 15 15W-40 oil. Dang it...15 quarts is overfilled. Check the dipstick when I get home, yep definitely overfilled. Crawl under the truck to see oil filter leaking. Decide to not touch the oil filter. I also checked the oil about 1/2 hour later.
I drive back to dealer. Ask them what oil they use on the 6.7. He says whatever is printed on the cap. I tell them it says 15W-40 on the paperwork which is an approved oil but not what is listed on the cap. I also tell him it should be 10-30 dino or 5-40 synthetic. I then tell him the filter is leaking. It either wasn't tightened or the tech didn't ensure the gasket came off. I tell them that is the oil weight and quantity I used for my 7.3 and 6.0. 6.7 is supposed to get 13 quarts. Quick Lane service writer tells me that guy put the correct oil & quantity but wrote the ticket wrong. I asked him if he is sure because I checked the oil & the whole 'bullet' comes out wet. I say, "My confidence isn't that high right now."
They made it right but shouldn't the paperwork be correct? An oil change is about as basic as it gets....
Long Version:
I did check the oil cap & filter before driving off. Like I said, my confidence level wasn't too high. I know they change the oil. The oil cap was in a different position & printing on oil filter was in a different spot. Oil level was right when I checked it at home. Just a bummer that I had too.
I get that the LOF guys are low on the totem pole and training.....but dang!
Copy on the oil & filter from Amazon. Already have the supplies on the shelf. I was trying to save the $$$ but it ended up costing me half a day.
What I see happen a lot is the parts department doesn't get the memo (or in my case doesn't care). They continue to charge the amount of oil they're used to, and since they are using bulk oil, tech is responsible for the dispensing and may very well put the correct amount in but never sees/concerns himself with what amount is charged out.
But after five years of 6.7 oil changes....give me break. They should know better.
china marker for the tires too... I've asked for tire rotations and found that they were not done... I used to sign my oil filters too. Although I do my own oil changes. I have a hard time with the tire rotations and rebalancing.
I used the dealer free oil change coupon and also went in behind them. They did it right.
However, that wasn't the case with two different dealers on my 2011. One messed up the oil change (too much oil) and the other messed up the coolant.
Luckily I trust, but verify.
Just a reminder that I can document any feedback (positive or negative) about a dealership experience. Just PM me your full name, best daytime phone number, dealer info, and any specifics you'd like me to include. I'll do the rest.
Crystal
I never leave the quick change oil place at my dealer without having them show me the dip stick oil level. It's always been correct but my dealer seems to have the same people changing oil each time I visit. I certainly know of a local dealer that I wouldn't let put air in my tires. Not all dealers are created equal.
Outside of members here, I know of no people that still change their oil or even work on their vehicles at all. Each time we have a Dealer oil change thread, it always makes me smile to see all the Super Duty people that still maintain their trucks. I wonder if the F150, Escape, Edge, Fusion crowd is this hands on. I doubt it. Seems to be a Super Duty trait that I don't have.
bruce...
bruce...
I spend some time on the Focus ST/RS forums, and a lot of those guys do their own work. I've also have been on L-Body, Raptor, SHO, and Ranger forums, and the same goes for them, too. There are even a lot of BMW and Mercedes forum guys that do their own work.
This is crazy.
I don't have access to procedures or shop manuals; I'm sure the service manager at your local dealership would be happy to check for you, though.
Crystal
