Info about 460 swap
Old Feb 2, 2006 | 07:58 AM
i1dery's Avatar
i1dery
Info about 460 swap
Have a 77" highboy f250, My question is this.
It came with a 400ci eng and wanna know if a 460 will bolt up to it?
Old Feb 2, 2006 | 08:57 AM
Josh79's Avatar
Josh79
The 460 will bolt up to your transmission yes, but there is a little more to it but it isnt too bad as you can get everything you need from l&l products in there engine swap kits. Mounts, oil pan, headers, clutch, accesory drive mounts etc, plus you get some some extra things from them. Quite a few people have done it and i havent heard anything bad about there products. Edit: forgot there site http://www.landlproducts.com
Old Feb 2, 2006 | 09:31 AM
oldhalftons's Avatar
oldhalftons
if its an auto, it will bolt up.
if its a manual, it depends on what bellhousing it is and what type of clutch/spacer you use.
Old Feb 3, 2006 | 02:49 PM
trinogt's Avatar
trinogt
If you have a 460 parts truck around, you will have all you need. Or find one at the junkyard.
Mark
Old Feb 3, 2006 | 03:56 PM
F1rocco-NY's Avatar
F1rocco-NY
The 460 needs to have the different crankshaft in order to be mated to a Manual....Unless of course the 460 is already balanced correctly.....
Old Feb 3, 2006 | 09:08 PM
toddn78's Avatar
toddn78
I took my 351m out and put a 460 in with a manual transmission. It was quite expensive to do it right. So have you wallet full and ready.
Old Feb 3, 2006 | 09:16 PM
Cowboy34's Avatar
Cowboy34
swap
you will have to cut a section out of the frame on the right side, for the exhaust manifold. I pulled a 460 out of my 78 and built a 400 to back in.
Old Feb 3, 2006 | 11:11 PM
F1rocco-NY's Avatar
F1rocco-NY
Just get the right right side manifold....Or Custom Headers..I had a truck that someone did that to...Looked sickening.....aggghhhh...I paid like $500 total for my headers for my Bronco but worth every cent.......Nickel Plated chrome lifetime war..3/8 flanged sold with pipe flanges ......
Old Feb 3, 2006 | 11:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
A 77 highboy with a 400??? A 400 would mean that it is a 77.5 model and not a highboy. Check the information on "Highboys" in the FAQ thread at the top of this 73-9 forum. Of course someone may have switched an engine out sometime over the years.
Old Feb 4, 2006 | 12:03 AM
highway90's Avatar
highway90
All possible questions about a 460 swap can be found on this guy's webpage. Check it out. He's knows his data...
http://www.73-79fordtrucks.com/Techtalk.htm
Old Feb 4, 2006 | 12:16 AM
FordPickup460's Avatar
FordPickup460
Some early 77 Highboys did come with the 351m/400, there are a few users on FTE who own them. I looked at one when I was looking for a truck a few years ago, 400, C6, Divorced NP205 with 36's on it and no lift.
Old Feb 4, 2006 | 12:20 AM
oldhalftons
early 77s certainly did come with 400's
Old Feb 4, 2006 | 12:22 AM
Torque1st's Avatar
Torque1st
Posting Legend
You mean "late" highboys... They were discontinued in 77 with the mid-year introduction of the 77.5 model (early 78). Ford does seem to make do with parts in stock at times. The round headlight grille used on the 78 custom is an example.
Old Feb 4, 2006 | 12:32 AM
oldhalftons
except he's absolutely wrong on the bellhousings, there are 3 diferent bellhousings.
a shallow 351m/400 bellhousing that needs a 1/2"-7/16" spacer and requires a 11" FE flywheel and diaphram clutch. you can only use this bellhousing with a pre-79 460 with an internal ballance crank
a deep HD 400 bellhousing that you can get away without using a spacer and a 11" FE diaphram clutch or a spacer and a 12" 460 diaphram clutch
a real 460 bellhousing that you can use a 12" 460 long arm clutch and needs only a stock block plate.
all 3 have the same bellhousing bolt pattern
Old Feb 4, 2006 | 12:44 AM
oldhalftons
no I mean highboys. early 77's with tank in cab, narrow frames, driveshaft between the trans and Tcase, and multi leaf front springs.
pre-Y20,001 not 77.5, not 78
highboys with 400's. I know exactly what I mean.
