dumping problem
Old Jan 17, 2008 | 06:20 PM
projectcasper's Avatar
projectcasper
dumping problem
New to the PSD scene but I purchased a 97 F250 PSD and when i start it up it sounds like a wastegate is dumping. I cant take off driving it until it stops which is usually about 10 to 15 secs. but the issue I am haveing is that sometimes it doesnt make the noise and when i take off driving it will act like it is dumping the whole time. I was told that it was the turbo mount. I unplugged the exhaust back pressure sensor and the problem went away. is the sensor bad or is the turbo mount bad? And just curious will a 1999 and up turbo fit on my truck with my mount or do i have to use a different one?
Old Jan 17, 2008 | 06:26 PM
F0rdF0rever's Avatar
F0rdF0rever
Your turbo is fine. It was just the ebpv acting up. Most guys here unplug them for the same reason.
Old Jan 17, 2008 | 06:40 PM
projectcasper
thanks. how easy is it over spool the turbo
Old Jan 17, 2008 | 06:44 PM
custom_nirvana's Avatar
custom_nirvana
i thought our 7.3 werent wastegated?
Old Jan 17, 2008 | 06:48 PM
projectcasper
that is what it sounded like.
Old Jan 17, 2008 | 06:49 PM
projectcasper
Will a 1999 and up turbo fit on a 97 model
Old Jan 17, 2008 | 07:15 PM
custom_nirvana
Yes, its the 1.0 houseing. If you do a search on here you should be able to find alot of info on it.
Old Jan 18, 2008 | 12:34 PM
jjcox's Avatar
jjcox
Same problems here, I can see the valve, but how and where do I disconnect it? is it an electrical, phnuematic, or mechanical disconnect I need to do?
Old Jan 18, 2008 | 12:52 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
here
Read this link: https://www.ford-trucks.com/forums/6...rbo-sound.html
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
BTW welcome to FTF
Old Jan 18, 2008 | 12:54 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
BTW, welcome to , you are going to learn a lot here.
Old Jan 18, 2008 | 01:23 PM
jjcox's Avatar
jjcox
Thanks!, I have been reading, watching, and learning from this site for quite a while already, I've just never registered or posted anything until now.
Old Jan 18, 2008 | 01:26 PM
Todd525's Avatar
Todd525
I wish I had a nickel every time someone thought there was a problem with their truck and it was the EBV. On second thought, I wish I could punch the engineer in the face everytime someone thought they had a problem with it. What a waste of fords time, money, and man hours in designing this POS.
Old Jan 18, 2008 | 01:55 PM
tjbeggs's Avatar
tjbeggs
not without a few other parts will be needed, like the pedestal, up-pipes, downpipe, intake y-pipe, turbo.
ldapprich
Apr 1, 2017 10:52 PM
Reaper76
May 10, 2016 02:23 PM
jaymo8989
Jun 1, 2015 12:55 PM
dsbrew1
Jul 4, 2011 11:09 PM
Skinsfan6
Apr 26, 2011 08:48 PM
