missing almost nocking sound on cold startup.
Old Jan 17, 2008 | 10:50 AM
61 uni's Avatar
61 uni
I brushed the snow off and started my truck this morning and it made a missing almost nocking sound. Is this the romps? It never died and cleared out in a few seconds.
Matbe it is just loping?
Old Jan 17, 2008 | 05:52 PM
WALJON's Avatar
WALJON
Cold morning start. what is the temp? if you are not used to it you will think that something is totally wrong, was it plugged in?
I have started mine plugged in at -35c and it sounds like it is running on One cylinder till it clears out then it runs fine diesels do not start good cold
Old Jan 17, 2008 | 08:09 PM
johnstoys2's Avatar
johnstoys2
It's called a fuel knock & It's because the one missing cylinder is starting to load up on unburned fuel till it gets warm enough to fire normaly. probably a dead glow plug.
Old Jan 17, 2008 | 09:17 PM
WALJON's Avatar
WALJON
yes it prob is a glow plug ,but if it is cold enough it won't matter if the glow plugs are working or not it will still do it
Old Jan 18, 2008 | 08:06 AM
61 uni's Avatar
61 uni
It was plugged in for about 30 min.
Old Jan 18, 2008 | 11:43 AM
skittlejr's Avatar
skittlejr
30 min. isn't much time to have affect. will help, but if it's really cold it wont eliminate rough cold running.
Old Jan 18, 2008 | 12:40 PM
97REDPSD's Avatar
97REDPSD
Sounds normal to me but like they said might check glow plugs and leave it plug in overnight so the heater can work faster.
Old Jan 18, 2008 | 03:04 PM
Robbgt's Avatar
Robbgt
Block heater needs 3 hours to be affective (per manual). I have brand new GPs and a Stancor GPR (way better than stock) New batteries, batt cables and starter. If it 10* or colder and I don't plug it in, mine will still have a fuel knock. I know all the GPs are good, just cold enough that it does it. If i have it plugged in on my outdoor timer, for 3 hours no Knock. But yes that is normal for really cold. May have a dead GP or 2 also if haven't been changed in a while.
-Robb
Kennedy2
Modular V8 (4.6L, 5.4L)
116
Mar 5, 2025 08:58 PM
annaleigh
Nov 13, 2015 05:37 PM
strickland
2015 - 2020 F150
Aug 6, 2015 10:12 AM
97intimidator
1997 - 2003 F150
Jun 18, 2004 06:17 AM
drunkenmonk
Jan 1, 2004 02:02 PM
