Sponsored by: Auxito
150 Lariat heater problem
Old Jan 17, 2008 | 06:45 AM
hammerhead3006's Avatar
hammerhead3006
2003 F150 Lariat Defrost and dash panel work great but when I push the button for floor I get almost nothing. What should I be looking for????
Old Jan 17, 2008 | 10:11 AM
MrBSS's Avatar
MrBSS
System defaults to defrost for safety reasons. Most likely cause is a vacuum leak. However, you apparently have ATC, and it could be a number of things.
Old Jan 17, 2008 | 11:18 AM
KingRanchMan02's Avatar
KingRanchMan02
The EATC has a diagnostics mode built into it. Follow the procedure below and tell us what trouble codes it comes up with. Good luck!
Electronic Automatic Temperature Control Module Self-Test
The EATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A scan tool must be used to retrieve these concerns.
The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4º-32ºC (40º-90ºF) when performing the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed.
The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
  • To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
  • If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
  • If a condition exists but no DTCs appear during the self-test, refer to the Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
  • To exit self-test and retain all intermittent DTCs, push the blue (cooler temperature) button. The control will exit self-test, retain all intermittent DTCs and then turn OFF (display blank).
  • To exit self-test and clear all DTCs, press the DEFROST button. The vacuum fluorescent display window will show 888 and all function symbols for one second. Then, the EATC control assembly will turn OFF (display blank) and all DTCs will be cleared.
  • Always exit the self-test before powering the system down (system turned OFF).
  • Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
Old Jan 17, 2008 | 07:14 PM
steve(ill)'s Avatar
steve(ill)
there are 3 different plastic doors in the air duct that direct air to the defrost, panel, floor, or combination of the above. each is controlled by a small vacuum cylinder. the hoses all run to the control panel switch. i would assume a hose came off the control panel, or the cotroller assembly leaks thru.
aclan
2009 - 2014 F150
Aug 31, 2016 11:07 PM
Hammer40330
Mar 23, 2016 03:05 PM
Greenie326
2015 - 2020 F150
21
May 5, 2015 04:34 PM
Spitz
1997 - 2003 F150
Oct 11, 2009 06:43 PM
phoneman71
Dec 23, 2004 08:45 PM
