What next for my late model 460. Opinions?
I've installed a home brew FIPK intake clone, a set of long toob headers, a 3" exhaust system, advanced the timing almost up to the rattle point. Good improvements so far.
What would be a worthwhile next step performance mod without pulling the heads off? An MSD ignition? Is there such a thing as higher ratio standard or roller rockers? How about an Edelbrock performance throttle body? Don't have the $4,000 for a blower!
Sorry El Guapo, the EFI 460 is not a cheap beast to modify. MSD won't really do anything for you. To be able to do any engine mods you will need to do do a MAF conversion, then the world of mods will open but not till the tune of $1000 for the MAF. For the time and money I am waiting to save up for the vortech SQ s-charger. I have found it new on the net for $2499.
What would getting a higher stall convertor get him? He would just have to wond the engine out more before the truck started moving. convertor stall speed is also based on torque and engine vacuum values, so unless he does a cam change there would be no benefit to getting a new convertor. Or am I way off base here?
on
I'm just suggesting a mild step up in the converter...400-500 RPM over what he has stock. TCI makes the 11" Street-Sizzler which he can purchase for $132 mail order from Summit or Jegs. I quote from TCI: "This converter is a step above stock and is designed for use in street or mildly modified vehicles. You'll get quicker acceleration, better low-end power and a smoother, cooler running transmission without any internal modifications."
I would consider his vehicle "mildly modified" with his already finished intake and exhaust modifications. A $132 converter upgrade is a pretty cheap improvement if he can do the labor. Just my 2-cents...Deen
hey,just out of curiosity,what kind of mileage are you guys getting out of your big blocks.i have a 97 f250 hd crew 460 4x4 auto......7~9mpg.it is brutal.already have removed emissions(smog pump,cat)running a single race flowmaster,k&n stock replacement filter.i dont know where else to go?
