Tsb 07-16-01
Old Jan 16, 2008 | 04:07 PM
n3hcp's Avatar
n3hcp
Question Tsb 07-16-01
I just got my '06 F-250 SD back from the shop. It was in for routine service and last week it got a check engine light. The code was P0299. The dealer replaced the EGR solenoid and cleaned the turbo per TSB 07-16-01. After searching all the TSB data bases I could find, I can't seem to find that one. Does anyone know what it is?
Second question...Last summer I shattered my right leg and as a result the truck has spent most of the last 6 month in the car port. My wife isn't a "truck person" so it's only been driven less the 100 miles since July. I'm suspecting that may have something to do with the problem. Any thoughts??
Old Jan 16, 2008 | 04:20 PM
69cj's Avatar
69cj
That lay over could have caused the turbo problem and if your fuel was stale that could have contributed to both. If you had no fuel additives in the tank I would stongly be considering changing the fuel filters once I filled up with fresh fuel and also put some Power Service or Stanadyne in the fuel tank just to be safe. Just my opinion.
Old Jan 16, 2008 | 04:24 PM
Maxium4x4's Avatar
Maxium4x4
TSB 07-16-01 is the guideline for turbo cleaning or replacement for the technician to follow.
Old Jan 16, 2008 | 04:47 PM
n3hcp's Avatar
n3hcp
Originally Posted by 69cj
That lay over could have caused the turbo problem and if your fuel was stale that could have contributed to both. If you had no fuel additives in the tank I would strongly be considering changing the fuel filters once I filled up with fresh fuel and also put some Power Service or Stanadyne in the fuel tank just to be safe. Just my opinion.
Thanks! The tanks (stock tank and 50 gal aux tank) were both filled in July and has the recommended amount of Diesel Kleen added. The filters were replaced when it was in the shop. Now that I can, I will drive the truck as much as possible to get some fresh fuel before the summer camping season is upon us! We usually take a long trip or two later in the summer so maybe I'll replace the fuel filters again before that.
Old Jan 18, 2008 | 10:45 PM
nitrogen's Avatar
nitrogen
not sure where you live but if you fueled in summer you have summer blend which has a higher temp cloud point. not a good thing if your temperatures change much from summer to winter
Pilgrim
45
Feb 1, 2018 08:22 AM
GuitarJesus
May 12, 2015 09:32 PM
Thom12
6.7L Power Stroke Diesel
13
Feb 22, 2015 01:46 PM
riverrat69
6.4L Power Stroke Diesel
17
Jan 11, 2009 10:30 AM
pilotshot
Dec 15, 2008 08:22 PM
