Does anyone know if this era of ford trucks came with a radiator overflow tank? If not would it be any trouble putting some sort of catch can for the radiator overflow line?
Thanks.
My 79 Lariat has one that looks to be factory,but I haven't looked at it to hard.On my other trks I just zip tied a gallon antifreeze jug next to the radiator and just ran the over flow hose into it.Some schools of thought are just fill the system cold and when it gets hot whatever it pukes out it sets itself.Not to PC in this day and age
I have this one installed on my truck BVR4 www.kragen.com just copy and paste that number in the search. It works well.Just make sure to use a radiator cap that supports a coolant tank. Some caps won't allow coolant back in.
Thanks.
There's a couple..
D0AZ-8522-A .. Coolant Recovery Kit
Fits everything.
It was a dealer installed option, or could be purchased "over the parts counter" and installed by the owner.
The kit consisted of a whitish plastic reservoir, cap, a radiator cap (that stated: "Do not open"), hose, and mounting hardware.
Then there's this factory installed coolant recovery reservoir.
D1TZ-8A080-A .. Reservoir, Coolant Recovery
Used on: 1971/74: E100/300's & F100/250's with a 240 or 300 engine.
That's all Ford offered 1973/79 for Econolines & F100/350's.
Most of the cars had them....the windshield washer reservoir was divided, part of it contained the washer fluid, the other half was for coolant recovery.
I have one from a 78 Bronco... has a D3TA part #, looked factory installed on the Bronco. No one ever cleared up what it's from, but I figured factory 73-79 trucks.
Ahh.. I was curious what it was from, thanks! I had always thought the baby Broncos had their own suffix in the parts numbering system. (T=truck, etc). Never even crossed my mind.
Whatever the case, it looks factory, and fits the spot. Maybe they even repro these?
Ford confusion.
1966 = New Bronco comes out, and what does Ford do?
They use the trucks T in the part number prefix (C6TZ), but used a U in the parts catalog to ID the model. Why did they do that? Dunno.
When Econolines came out in 1961, Ford listed them under E in the parts catalog, but used a U in the prefix (C1UZ). Why?
1958/60 Edsel...used both an E in the part number prefix and was ID'd as such in the parts catalogs.
There was supposed to be a 1961 Edsel...not the previous full sized car, but a compact version.
At the last minute, Ford changed the 1961 Edsels name to: COMET.
Comet: K in the p/n prefix (C1KY), C for the parts catalog ID.
Part number prefix: Last digit is a Z for Ford parts, Y for L/M parts.
More Ford confusion: The Y parts can be used either on Fords or L/M's...except (usually) on body parts.
