FE AND FT starter ?
Old Jan 15, 2008 | 01:48 AM
ford390gashog's Avatar
ford390gashog
FE AND FT starter ?
Are the starters the same? They look 100% identical.
https://www.ford-trucks.com/forums/6...ml#post5577454
Old Jan 15, 2008 | 07:54 AM
HOTWRENCH's Avatar
HOTWRENCH
Starters
Yes they will interchange.
Have A Good Day----Hotwrench
Old Jan 15, 2008 | 10:18 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Um, be aware of the tooth count on the bendix gear.
They are (or can be) different.
The FT uses a coarse tooth count, the FE uses a finer tooth count, I believe. The early FEs use the coarse tooth count... again, I believe.
Old Jan 16, 2008 | 07:37 AM
HOTWRENCH's Avatar
HOTWRENCH
Talking Starters
I know from personal experience that FE @ FT starters will interchange. If you go to the local parts store they list the same starter for both--also the same starter drive. I looked at a FE and a FT flywheels this morning other than the casting numbers --weight cast into the FT none on the FE they were identical as far as starter teeth is concered. I've noticed that most of the ones i've pulled from FT's are the 41/2" type and many that come from cars are the 4" style.
Just some observations from many years in the salvage business.
Have A Good Day-------Hotwrench
Somemedic
Jun 18, 2015 04:18 PM
America
Aug 28, 2013 05:35 PM
kupaa
15
May 16, 2012 06:33 AM
Rory_Johnson
18
Jan 22, 2011 04:53 PM
Truck451
Large Truck
Jan 13, 2010 07:44 AM
