Offroad & 4x4
questions about sas
Old Jan 14, 2008 | 01:03 PM
Kylet8020's Avatar
Kylet8020
questions about sas
<TABLE><TBODY><TR><TD vAlign=top width="100%">i have a 85 f150 4x4 been told that a sas would give a better ride and not eat tires first question is this true 2 question do i have to lift the truck 3 question do i need to buy a kit or can i pull all the part off a junkyard truck 4 question what year axle am i lookin for 77-79 is what i think i need 5 question after this is do i would like to lift it but not now could a d44 handle 35 12.50 tires?
</TD></TR></TBODY></TABLE>
this is also in the 80-86 fourms but i thought maybe u off road guys would be able to put some light on this i searched it but did not find to many people askin same question in the end i want the truck to have a 6in lift with 35x12.50s and use for dd weekend warrior and to do some towing mostly for cars that will be goin to the crusher its got a 351w ho that i wanna rebuild or i have the 300 inline 6 that came out of it its being rebuild as of now back to stock might do just a few mild mods to it what ever engine i use will have a 435 that has less then 2k miles on it or ill switch to a auto c-6 if i do that i would like to have a over drive i hear there are some nice units but i need more info on them to
recap
1985 f-150 4x4 long bed reg cab with 300 6 or 351 w 6 in lift 35x12.50s with sas for weekend war dd and towing thats the dream any way
Old Jan 14, 2008 | 01:10 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
you could easily answer all your questions with just a little research, a GREAT place for SAS info is on FSB, they have a forum for just SAS's.....here you go
http://www.fullsizebronco.com/forum/...splay.php?f=29
or ditch the d44 and run some rockwells
Old Jan 14, 2008 | 02:10 PM
Kylet8020's Avatar
Kylet8020
srry for askin so much but i doin all this on a ps3 a its sloooooow
Old Jan 14, 2008 | 04:01 PM
TN97STROKE's Avatar
TN97STROKE
Question #1 Not a better ride........but not a bad ride/ yes on the tires
Question #2 Yes to clear the cross member and then it still need some minor modification.
Question#3 You can get most of the parts from junk......hardest part is the steering(DON"T CUT CORNERS) takes a little work to get caster right but not to hard
Question #4 78-79 reverse cut
Question #5- yes
Old Jan 15, 2008 | 09:33 AM
teds74ford's Avatar
teds74ford
My take on the axle is get a 76-77 if you are going with a dana 44. They have one piece tubes that are thicker than the 78-79.
Old Jan 15, 2008 | 12:35 PM
STGFordCrazy04's Avatar
STGFordCrazy04
A question about your question #2.....
If you dont plan on lifting the truck then why go through the trouble/cost of doing a SAS? The TTB axle under the truck now will hold up fine with 35s and I doubt you will ever realize the sas saving you money on tires. Cost to do vs cost of say 4 new front tires.
Slap a 4" lift on it with the ttb drop brackets and call it a day. I love my 300-6 in my 79 f150 but the aftermarket is flooded with winsor parts. If someone had the desire they could build a jam up 500hp stroked winsor and for pretty cheap. You cant say that about a 300....even turbo'd.
Old Jan 15, 2008 | 01:14 PM
i1dery's Avatar
i1dery
I put a 4 inch lift on my truck 89' with a ttb and my wheels are as straight as an arrow really hav'nt had any problems with tire wear. I really must've instld my lift
just right cuz really your not the first to have worn tires.
Old Jan 16, 2008 | 06:38 PM
Kylet8020's Avatar
Kylet8020
i want to lift the truck about 6in but i read some where u break u joint quicker because of the angles any truth to this
Old Jan 17, 2008 | 07:28 AM
i1dery's Avatar
i1dery
I have'nt yet, and im not like what you'd call easy on equipment, but then again I only have a four inch lift to keep center of gravity down slightly.
thedaddycat
Oil & Lubrication
Feb 27, 2008 06:12 AM
bestdjsnc
6.4L Power Stroke Diesel
Feb 22, 2008 08:19 PM
LostMayhem
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 9, 2008 12:17 AM
drunkenrich
Offroad & 4x4
23
Dec 28, 2007 09:56 PM
gsg1970
Mar 14, 2007 04:19 PM
