big Holley
Old Jul 3, 2002 | 02:48 PM
dpoelstra's Avatar
dpoelstra
big Holley
On my 86 F350 I have a big Holley Carb. I understand that this is factory, but does anyone have any info on which carb this is or how to tune it?
86 F360 Crew Cab Dually
460, C6
Old Jul 4, 2002 | 02:35 AM
Superdave's Avatar
Superdave
big Holley
If it says on it thats its a Motorcraft caburetor made by Holley it would be a 600cfm unit. Its a 4180. It is similar in function to the 4160 Holley.
Old Jul 4, 2002 | 10:27 AM
dpoelstra's Avatar
dpoelstra
big Holley
It doesn't say "Motorcraft" anywhere. Just a big "Holley" on the front. Is this original? Maybe this is an after market carb? Isn't a 600cfm unit kind of small for a 460 on a dually?
Old Jul 5, 2002 | 03:00 PM
Superdave's Avatar
Superdave
big Holley
There are numbers on the front of the air horn. What are they? I contacted Holley a while back about the carb (Holley made for Motorcraft) I had, which was off a 79 E-250 van with a 460. That is what they said it was a 600 cfm carb. They called it a 4180C.
Old Jul 5, 2002 | 08:29 PM
phantom429's Avatar
phantom429
big Holley
I agree with superdave. The Holley carbs on the 460's are specially made for Ford by holley. They are a 600cfm, vacuum secondary smogger carb. There will be one large vacuum nipple on the top of each float with a hose going to the E.V.A.P. system. These carbs work excellent for those who only use their vehicles to get groceries and for those crazy and wild nights of bingo. However I tend to use them to weigh down my garbage can. If however you need to tune it, the idle mixture adjustment is on the base of the carb at the front. The screws (if I can remember) are allen heads.
Old Jul 8, 2002 | 03:48 PM
dpoelstra's Avatar
dpoelstra
big Holley
the carb is labeled "Holley" on the front, with the numbers as follows:
E5HE-9510-MC
List 50262-2
0446
Recomendations on a carb? I tow a 7k lb fifth wheel.
Thanks much
Old Jul 8, 2002 | 06:19 PM
Superdave's Avatar
Superdave
big Holley
[updated:LAST EDITED ON 08-Jul-02 AT 07:24 PM (EST)]That is a Ford - Holley. The E means 80's model and the 5 designates the model year, being 85. So it is a built in 1985, Holley made for Motorcraft, 600 CFM carburetor. As far as recomendations, I rebuilt mine and had no problems with it. But my son wanted to put a new Holley on the truck, but still replaced it with the 4160, 600 CFM. Pretty much the same thing. It gets 10.5 mpg.
Old Jul 8, 2002 | 07:09 PM
dpoelstra's Avatar
dpoelstra
big Holley
Thanks...This one needs to be overhauled, so I wanted to make sure it was worth keeping. Will upgrading to a 750 cfm have better performance for towing, and is it worth the expense?
By the way, my F350 CC dually gets around 6.5 mpg. I am hoping that a carb overhaul will help a little.
Thanks again for your help and knowledge.
Old Jul 9, 2002 | 10:21 AM
laptopgeek's Avatar
laptopgeek
big Holley
Need a bigger carb? I have to offer my 2 cents here.....the Holley Avenger 770 I have on Harrison has too many ponies for Harrison....talk about TORQUE...he chews up mountains and then spits them out....he WAILS going uphill...gotta be careful - the speedometer will peg out v-e-r-y- quickly.
I would not hesitate to go from a 600 to a 770. You'll develop a "first name relationship" with all the local fuel stops, though....
Old Jul 11, 2002 | 01:25 AM
Superdave's Avatar
Superdave
big Holley
dpo, Have a look here.
http://www.performanceunlimited.com/documents/cfmguide.html
Old Jul 11, 2002 | 11:00 AM
laptopgeek's Avatar
laptopgeek
big Holley
Xwarrior86
Feb 18, 2013 08:08 PM
zman300
Large Truck
Jul 21, 2011 05:12 PM
Slowdog
Feb 3, 2011 06:04 PM
vito
May 4, 2005 07:24 PM
cjben
May 12, 2003 02:35 PM
