I have a 460 in a 1986 e350.
I wanna know how to adjust the carb to have a good idle.
Mine is a bit erratic and stall some times with the automatic transmission engaged. I think the carb needs an overall because I have some probs with the choke too. On the road everything is O.K.
Wally - we need to know the carb you're using....I have the same engine as you; I put it in my 74 F100, but the engine now has a Holley Avenger 770CFM carb - it's settings are different than, say a...Rochester or Carter or Edlebrock....
