Fuel line restrictors
Old Jan 13, 2008 | 09:03 PM
puffen:D's Avatar
puffen:D
Question Fuel line restrictors
Looking over some old threads on different things that have been done, I can across one on removing the restrictor fittings and putting ones in that are open. This sounds good to me but it begs the question of why they were in there in the first place? I'm sure somebody in design thought they were needed for some reason. What problems could come up by taking them out?
Old Jan 13, 2008 | 09:53 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
They were supposed to be checkvalves, to hold pressure in the heads which takes more stress off the pump when it's trying to build 55psi of pressure.
Old Jan 14, 2008 | 02:39 PM
puffen:D's Avatar
puffen:D
Thanks for the reply, I've been traveling and just got on to check. If a person removes the checks does it cause any problems with starting or pump function/longevity? If a person does the CCK the pressure would bleed thru the orfice anyway right so would the regulated return work better or not?
Old Jan 14, 2008 | 03:57 PM
PowerstrokeJunkie
Actually another thing that they do is isolate the pressure waves inside the heads. When each injector fires, it accepts more fuel, in turn making a pressure wave. If this isn't isolated it theoretically can damage an external diaphragm regulator, and even the fuel pump. Never heard of it happening though. Shouldn't be a problem removing them.
Old Jan 14, 2008 | 06:55 PM
puffen:D's Avatar
puffen:D
Is there a number of people out there that have removed them and how long have they been out? Any problems? This really looks like something I'll like to remove but I hate going against design unless its been proven to work and give benefit.
Old Jan 14, 2008 | 07:50 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Mine have been out a couple years as have many folks. Here are some pics of the rascal:
And finally
Old Jan 14, 2008 | 09:00 PM
greagin's Avatar
greagin
and where exactly are these things located?
Old Jan 14, 2008 | 09:41 PM
puffen:D's Avatar
puffen:D
Do both of them have the screen in them or does one have the poppet and the other the screen?
Old Jan 14, 2008 | 09:43 PM
PowerstrokeJunkie
Its a bulkhead fitting that connects the fuel line at the rear of the passenger head and the front of the driver's side heads to the cylinder head.
Old Jan 14, 2008 | 09:49 PM
bdrummonds's Avatar
bdrummonds
I removed mine when I installed a new fuel system with bowl delete. Just let your fuel pump rum a few seconds before cranking truck while the WTS light is on, 3-5 seconds is all it takes to build the pressure.
Old Jan 15, 2008 | 05:29 AM
puffen:D's Avatar
puffen:D
Does it help any with the low fuel flow to #8?
Old Jan 15, 2008 | 09:19 AM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
What does this do for ya? Is there a step x step instruc. somewhere?
Old Jan 16, 2008 | 12:47 AM
cdiddy's Avatar
cdiddy
I would also like to know if there is a write up on this anywhere.
Old Jan 16, 2008 | 12:57 AM
Tenn01PSD350
I fooled with this some time ago. Here is the link to the thread.
jmcnair40
32
Jun 16, 2021 10:57 PM
overbore66
Jul 5, 2010 10:50 AM
fredzeppelin
Aug 1, 2006 10:44 PM
lumbrjak472
Feb 3, 2004 05:52 PM
