Missouri Chapter Join Chapter , Leader:77&79F250
Still Full?????
Old 01-13-2008, 04:06 PM
ubereal2's Avatar
ubereal2
ubereal2 is offline
Still Full?????
I like drive the 79 once in a while to work, just to drive my play toy. I ran around Springfield some friday while I was off. Saturday I drove it to work, to Strafford, just under a 30 mile drive each way.
I haven't fixed the fuel gauge yet and knew it couldn't have much fuel left. So on the way back home from Strafford, I stopped in Springfield. Removing the fuel cap, there was gasoline sitting just behind the cap. Would only take a couple cups of gas.
I drove on home, (Ozark) stopped again, then it took almost half a gallon. I know this truck better than that. That thing should be down by atleast 10/12 gallons.
I ran a cable down the filler neck. Figure maybe somebody put a golfball something in the tank. Cable went all the way to the tank.
Any Ideas????
Bob
Old 01-14-2008, 11:45 AM
UncleD's Avatar
UncleD
UncleD is offline
Gas fairy?
Sorry couldn't resist
No ideas on why it's not using fuel.
Old 01-14-2008, 02:09 PM
tcbofade's Avatar
tcbofade
tcbofade is offline
How many gas tanks to you have?
(Are you running off of the rear tank and trying to fill the front tank?)
Old 01-14-2008, 08:50 PM
Brawny's Avatar
Brawny
Brawny is offline
Does it have a breather hose for the tank? If so maybe its clogged not letting air out while you fill? Other than that or the two tanks as mentioned above I have no idea.
Old 01-14-2008, 09:01 PM
ubereal2's Avatar
ubereal2
ubereal2 is offline
One tank. Not sure if the other hose/ube is clogged or not. But the last time I tried to fill it, it only took $1.60. Should need near 12 gallons.....
Old 01-14-2008, 11:48 PM
Brian_B's Avatar
Brian_B
Brian_B is offline
Ummm...No clue, but I want to hear how this turns out.
If you are getting that kind of fuel mileage...you may put exxon out of business.
Old 01-15-2008, 06:55 AM
tcbofade's Avatar
tcbofade
tcbofade is offline
Yeah, keep us posted.
A fairly common issue that you MAY be having...sometimes, as the bed supports rot away, the bed starts to rest on the filler hose and/or breather hose, which will block off the flow of fuel into the tank and/or vapors out of the tank.
A year or so ago, I had to drop my front tank (the only one that works...) to replace the above mentioned hoses...while it wasn't fun, it wasn't too awful bad, either. As you can no longer purchase the skid plate, I had to do some custom fabbing to install straps to hold the flippin' thing in, but as I said, it wasn't too horribly difficult.
If you've only got one tank, I imagine it's behind the rear axle, correct? Dropping that tank should be easier...and the hoses weren't expensive. Crawl on down there and look!
Old 01-15-2008, 01:35 PM
6L PWR's Avatar
6L PWR
6L PWR is offline
That's just one reason not to use wood!
For those that do not know, TCBOFADE has a 2x4 battery hold down! ROFLMAO!!
Old 01-15-2008, 01:46 PM
tcbofade's Avatar
tcbofade
tcbofade is offline
Ya know, I'd thought of that today...and you, 6L Loser...
If the bed sagging is the problem, and Bob is not in the mood to fix it properly, he could use a bottle jack to raise the truck by the bed...just enough to jam a piece of 2x4 between the frame rail and the bed near the pinch point...then secure it with....
Old 01-15-2008, 01:48 PM
tcbofade's Avatar
tcbofade
tcbofade is offline
...and it's still working, too.
Old 01-15-2008, 03:09 PM
67nukeford's Avatar
67nukeford
67nukeford is offline
[QUOTE=6L PWR]That's just one reason not to use wood!
For those that do not know, TCBOFADE has a 2x4 battery hold down! ROFLMAO!![/QUOTE
Hopefully its something nice, maybe a nice mohogany or cherry, you know, give it that sophisticated look.......
Old 01-15-2008, 03:11 PM
tcbofade's Avatar
tcbofade
tcbofade is offline
Gimme a minute...there's a pic on this here website somewhere...
EDIT...ya see, there's something to be said for common sense...
https://www.ford-trucks.com/forums/s...1&postcount=81
Old 01-15-2008, 03:15 PM
greythorn3's Avatar
greythorn3
greythorn3 is offline
well it gives me wood anyhow!
Ray
Old 01-15-2008, 03:17 PM
tcbofade's Avatar
tcbofade
tcbofade is offline
Ray
Oh Good Lord...thanks for sharing that...
Old 01-15-2008, 03:51 PM
67nukeford's Avatar
67nukeford
Ray
Okay, that's just waaayy too much info........
Quick Reply: Still Full?????
