Sponsored by: Real Truck
transfer case fluid?
Old Jan 15, 2008 | 04:34 AM
ford390gashog's Avatar
ford390gashog
Originally Posted by redford
Those 1980 3wd Power Stroke trucks are very rare
Yeah super rare , not to mention Ford didn't even have a diesel until 1983
Old Jan 15, 2008 | 06:35 AM
Keith Smith's Avatar
Keith Smith
Originally Posted by JOE-M
You can still buy all the Mercon ATF that you could possibly want. No, It's not Ford's Brand, But it still meets the specs for Mercon/Dexron III transmission fluid.
Joe
I stand corrected. It was the reformulated Motorcraft Mercon V that I put in mine. My parts guy at the Dealer (a trusted friend for 15 years) advised me that it was completely compatable and better for my truck. Not experiencing any problems to date. I wonder how to tell if the stuff at Wal Mart is regular Mercon V or the reformulated that is supposed to be compatable with the old Mercon? I'll just keep getting it from my friend at the parts desk, he charges $3.50 / quart and that's comparable to the local stores.
Old Jan 15, 2008 | 08:25 AM
redford's Avatar
redford
FTE Leadership Emeritus
Yea....not to mention no Powerstrokes until the late 90's.
Old Jan 15, 2008 | 05:33 PM
oltrucker's Avatar
oltrucker
i have used synthetic gear lube in every chain drive i have ever had. the chain in my transfer case is a hy-v sileent chai. every use of them in industry calls for synthetic gear lube. these ford engineers are idiots. atf has no business being in any chain drive.
Old Jan 16, 2008 | 10:23 AM
krewat's Avatar
krewat
Did you read what I had to say about the planetary gears for 4LOW?
Old Jan 18, 2008 | 08:52 PM
Gage2502's Avatar
Gage2502
Question does the transfer case fulid ever mix with the transmission fulid?
Its two different units right?
I was going to use Mobil-1 for the transfer case.
~Gage~
Old Jan 18, 2008 | 09:09 PM
Alpine6's Avatar
Alpine6
Schaeffer's ATF in mine. Don't notice a difference, but it still works. BTS recommended it for the t-case as well as the transmission.
Old Jan 18, 2008 | 10:34 PM
krewat's Avatar
krewat
~Gage~
Yup, two different units.
I replaced my transfer case oil with Castrol Syntec Mercon about 3 years ago. It seems to engage and disengage a lot easier than the factory stuff. And I don't hear as much planetary gear noise in 4LOW, hardly any now.
I'd try the Mobil-1, based on what it did when I put it in the rear of my '01. When in 4x4 running at highway speeds, I'd get a slight gear hum from the rear - riding on the backside of the teeth with the front pulling. Switched to Royal Purple synth, some reduction in noise. Cover leaked, and I decided to try Mobil-1. Noise is GONE.
Decent stuff... but I won't run it in my engine ... personal reasons
Old Jan 19, 2008 | 12:59 PM
Gage2502's Avatar
Gage2502
Thanks guys for all your help.
~Gage~
Old Jan 19, 2008 | 07:22 PM
slowmans's Avatar
slowmans
well I decided im going to use royal purple max atf! thanks gents...
willpjones
Aug 19, 2016 02:41 PM
Andy Sullivan
Feb 15, 2014 04:52 PM
scar98
Dec 9, 2005 07:28 AM
proeliator
Offroad & 4x4
Jun 11, 2001 08:36 PM
Rob
Offroad & 4x4
Jan 28, 2000 06:47 AM
