rev limiter ?
Old Jan 13, 2008 | 10:39 AM
bambam1201's Avatar
bambam1201
Smile rev limiter ?
i have a 96' F-250 with a 351, the truck sometimes has a rough idle but the big problem is when i go to pass or get on the highway, if i press on the gas while in gear to much it feels like the truck completly cuts out after what seems like 5 or 10 seconds the engine comes back, is this a rev limiter or possiblt a problem in the tranny? please help
Old Jan 13, 2008 | 10:45 AM
Moore558's Avatar
Moore558
Sounds like a TPS problem to me.
Old Jan 13, 2008 | 10:50 AM
Conanski's Avatar
Conanski
Or a fuel delivery problem..
Or a partially clogged exhaust system.
Old Jan 13, 2008 | 11:03 AM
bambam1201's Avatar
bambam1201
any ideas on how to check for these problems
Old Jan 13, 2008 | 02:28 PM
fmr9's Avatar
fmr9
If you use the search function for this forum, you will be overwhelmed at the amount of info available. It works like this, either someone leads you step by step and types in the same thing they have done previously, or you do a search and ask when you hit something you don't understand.
First step is almost always pull the codes.
Good luck Frank
wwerner94
Dec 2, 2014 09:58 PM
smittybronco
Aug 17, 2013 09:08 PM
F3fitty
Oct 30, 2010 08:28 AM
mikeg81
1983 - 2012 Ranger & B-Series
Jan 4, 2008 01:39 PM
lee
Dec 1, 2003 03:42 PM
