Wheels And Tires
Old Jan 13, 2008 | 06:16 AM
SiverFox's Avatar
SiverFox
Smile Wheels And Tires
I have a 1995 F150 4.9 5spd 4x4. I'm fixing it up a bit. Its a good truck with 111000 miles. The truck came with 15x10 bullet hole wheels and 265/75/15 tires. the tires are too small for the wheels and the wheels are too big for the truck. By the way the truck is not lifted and I am not planning on a lift kit.
My question is, will 15x 8 wheels and 31/10.5/15 tires fit the truck?
Will they rub?
Thanks
Old Jan 13, 2008 | 08:35 AM
TexasGuy001's Avatar
TexasGuy001
That should fit nicely. That is probably what I would put on my truck if it was a 4x4. My truck has 15x8 with 255 70 15 tires.
Old Jan 13, 2008 | 09:10 AM
SiverFox's Avatar
SiverFox
Anybody else have this set up on their truck?
Old Jan 13, 2008 | 09:15 AM
95F350XL's Avatar
95F350XL
I know if you put a 31x10.5 on that 15x10 the tire wont fill the wheel out. Are the 31's a AT/MT tire. If there just street tires, id throw a set of 295/50/15's on. Nice and wide, and will fill the 15x10 out. I think thats the size. I have to ck with my friend, he has a set on his VW Dune Buggy, nice and wide and still have some hight to the sidewall.
Old Jan 13, 2008 | 11:19 AM
TexasGuy001
Running 31 10.50 15 tires on 15x8 is a fairly common setup. Especially on 4wd trucks. It will work on 2wd trucks. The only rubbing that might occur is on the radius arm. I have seen this quite often with stock wheels and 31 or bigger tires. This has to do with the offset. If you want more aggressive looking tires that are not the factory style pizza cutters then the setup your asking about will be a good choice.
Old Jan 13, 2008 | 02:58 PM
shtse's Avatar
shtse
I'm running 32x11.50s on 15" ford wheels, they work just fine and look great.
If you run 33x12.5, you'll have to shim the bumper to avoid rubbing.
