Does my truck have a rev limiter? 93 F350 460 C6... I was trying to race this large bag of douche in a tundra today and my truck acted like it had a rev limiter when I was in the high RPM range of 1st gear. It pissed me off. If I do... how do I get rid of it? I smoked him for the first 500 feet and then blahh.
Yes. IIRC it is somewhere between 4500-5000rmp. If you have the stock cam there is no point in getting rid of the rpm limiter. It will be out of the engine's powerband and you will actually be losing power, just shift to second next time. And good luck running a tundra. they are lighter and the 4.0 v6 model is the same HP as your 460 and the 5.7 v8 is 100hp more
Its an automatic and my truck weighs 4K and his was on 35s (probably stock gearing) and weighs 6k. We were side by side even after mine hesiated at the top of first.
Next time I'll know to back off right before it shifts.
Your truck does not weight 4k. It weighs more than 6k
hel my 2wd short bed lightning weighs 4400. without me in it
Im not sure with the 460 , my 302 hit the limiter around 5200 , if you leave it in drive it should shift before the limiter , if you do any work to the motor cam ect , you can get in the computer with a tuner & change the limiter & reset your shift points...Lew
