Clevor???
Old Jan 13, 2008 | 12:28 AM
factory594x4's Avatar
factory594x4
Question Clevor???
I have a 302 and I want to put my 400 heads on it. How hard is it? I understand I need a boss intake manifold, but that is not a problem. I have all the parts, so don't ask me why. (Just for fun really) I thought the only mod. was to block a water pass. here and open one up there??????
Old Jan 13, 2008 | 12:39 AM
baddad457's Avatar
baddad457
You got it. You need to plug the head coolant ports on the top corners of the deck face, where the coolant flows back into the block on a Cleveland, then drill new ones in the intake faces on one end of each to let the coolant flow to the intake passage. You'll need 7/16" head bolts long enough to thread into the block thru the heads too. Then Cleveland type pistons are needed that will work on 302 length rods, unless you have a set of Boss rods or 289 length rods to use with Boss 302 pistons.
Old Jan 13, 2008 | 12:42 AM
factory594x4
Question
why is the piston an issue? Why the change?
Old Jan 13, 2008 | 01:11 AM
fordeverpower's Avatar
fordeverpower
check out price motorsports for intake adapters.
Old Jan 13, 2008 | 06:34 AM
HemiEater's Avatar
HemiEater
because of the cantered valves.....
check my sig....for the 357Clevor build....got a few vids there too...
Old Jan 13, 2008 | 10:37 AM
baddad457's Avatar
baddad457
Right, in case you haven't noticed, the Cleveland's valves are not in-line like a Windsor head. Thus the valve reliefs in the piston tops are also different.
Yougotthehit
18
Aug 31, 2022 11:54 PM
john jamieson
Dec 1, 2016 06:52 AM
Cedarghost
Feb 21, 2016 09:02 AM
ralupien
2004 - 2008 F150
Jul 1, 2004 05:21 PM
John7894
Oct 24, 2002 05:12 PM
