HELP!! trans. stuck in second gear...
Old Jan 12, 2008 | 07:30 PM
RedneKRangeR's Avatar
RedneKRangeR
hello i got me a '88 ranger 4x4 v6 5sp. with a mitsubishi fm146
its stuck in second gear and wont shift into anything else. i am totally stumped and dont know what to do..
Thank you
Old Jan 12, 2008 | 07:48 PM
Greywolf's Avatar
Greywolf
If you remove your gearshift and boot, and look down the hole you should see three slots that the end of the stickshift rides in. The tracks on the left and right have small spring loaded buttons in them that have to be pushed outward to move them (the blue areas of the diagram I drew, below).
If one of the side rails is off-center (moved forward or back) you can't move anything else until it is recentered.
The diagram below is pretty much what it looks like in neutral - you need both buttons in the center, and you can move them with a big doggone screwdriver if your gearbox is not just plain frozen.
Look for the right side button to be slid forward, and try to get it back in the center.
- It will make a lot more sense when you see it at first hand.
Luck to ya! I just went through this with mine.
~Wolfie
Old Jan 13, 2008 | 05:38 PM
RedneKRangeR
thanks for the help!!
once i opened my eyes(and moved things around) i could see what you where talking about. got it going good.
the help was much apreciated!
Jonesy
Old Jan 13, 2008 | 09:06 PM
bazzman1953's Avatar
bazzman1953
Good ending to what could have been a bad situation. Thanks to Greywolf for his solution. This Buds for you!
Old Jan 14, 2008 | 07:09 PM
Greywolf's Avatar
Greywolf
Sometimes if there is play in the stick pivot - it can hop up out of the groove.
Not all trannies are the same either - some have sticks that are longer inside the tranny than others so be careful which sticks you use.
Old Jan 14, 2008 | 09:30 PM
RedneKRangeR
ya that might be part of the problem... the old stick that was in it had a bad bushing, so i went to the wrecking yard and got one out of a bronco 2 it was a little diff. i didnt think it was too diff. but maybe it is, because i do have a little issue getting into first gear sometimes...
Old Jan 14, 2008 | 10:13 PM
Greywolf's Avatar
Greywolf
Take a hard look at the original THANG. You might could "redneck" it better...
All it needs is to not slip up and down....
Better bolt maybe?
Otherwise you lookin' at replacing the shift lever. Price it, and let me know what they say.
Johnsbelljr
Mar 30, 2013 09:12 PM
89ford73
Sep 7, 2010 06:31 AM
phoneman91
Jul 17, 2010 03:11 AM
M Tucek
Aug 26, 2009 11:42 PM
jimbokicksasss
Nov 12, 2008 10:35 PM
