Tire pressure sensor question??
Old Jan 12, 2008 | 09:14 AM
engina's Avatar
engina
I upgraded my 2007 f150 xl from 17" hankook tires to 18" michelins....problem is the low tire pressure light has come on and wont go off....Ive checked the tire pressure and all are equal...any ideas on how to turn this light off, or what may be the problem????......thanks for any info
Old Jan 12, 2008 | 10:15 AM
thechief96's Avatar
thechief96
The pressure sensors are in you OEM tires and rims.
Old Jan 12, 2008 | 10:34 AM
BlueOvalFitter's Avatar
BlueOvalFitter
Question
Did you re-install the sensors on the new rims?
Old Jan 12, 2008 | 10:42 AM
engina's Avatar
engina
no I had no idea that they had them.............what to do now????
Old Jan 12, 2008 | 10:46 AM
BlueOvalFitter
Exclamation
You can remove them from your old rims and re-install them on your new rims.I read a thread here where they used some sort of epoxy to glue them to the rim then used tie straps to make sure they stayed secure.After you re-install them Ford can clear the light on your dash.
Old Jan 12, 2008 | 10:49 AM
BlueOvalFitter
https://www.ford-trucks.com/forums/6...highlight=TPMS
Old Jan 13, 2008 | 08:26 AM
03redstx's Avatar
03redstx
is there a way we can reset the light ourselves. i just picked up an 08 yesterday and immediately removed the 18"s. I put my blizzaks and winter wheels on ....the light is not my friend with only 120 miles on her.
Old Jan 13, 2008 | 09:43 AM
BlueOvalFitter
Exclamation
Not unless you re-installed the sensors.If you did,then Ford can clear the code.
Old Jan 13, 2008 | 01:03 PM
r95018's Avatar
r95018
We took aftermaket wheels which we had on an '04 Expedition (no sensors), and put them on an '07 Expy (with sensors). The warning light came on. Les Schwab, a local tire store, took the sensors off of the '07's wheels and put them on the older wheels which we were keeping on the new Expedition. We had to order a new attachment kit from our Ford dealer which consisted of straps and epoxy. The warning light cleared by driving around on them a little.
Old Jan 13, 2008 | 02:58 PM
mattd17's Avatar
mattd17
the easiest way around it if you dont want to have the tires un-mounted, and then re-mounted, is just to put the sensors inside a PVC tube, and pressurize the tube to the computer thinks they are inside the wheels correctly. then just hide the tube somewhere and your all set.
Old Jan 13, 2008 | 04:17 PM
BlueOvalFitter
Question
Do what?
Old Jan 13, 2008 | 06:34 PM
moonlighter's Avatar
moonlighter
Smile
Tire Pressure Sensor Light - Ford Truck Enthusiasts Forums
Here is a link to a tool to disengage tire pressure monitoe[if i did it right]
Old Jan 13, 2008 | 06:38 PM
BlueOvalFitter
I get an error code/page when I click onto that link.
Old Jan 13, 2008 | 06:42 PM
moonlighter
Okay i'm sorry, i did a search on [tire pressure monitor tool] try that.
Old Jan 13, 2008 | 06:46 PM
BlueOvalFitter
Question
Scroll up and click onto the link I provided in post #6.......is the picture of the tool in that post what you are referring to?
