Tire pressure sensor question??
Old Jan 13, 2008 | 06:49 PM
moonlighter's Avatar
moonlighter
YES that's it.
Old Jan 13, 2008 | 06:54 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Originally Posted by moonlighter
The post was made 12/27/07 by member ..ungotz....[tire pressure sensor light]
Yes,thats the post I was referring to.Click onto this link.
https://www.ford-trucks.com/forums/6...highlight=TPMS
Old Jan 13, 2008 | 07:29 PM
mattd17's Avatar
mattd17
Originally Posted by BlueOvalFitter
Do what?
you can get around the light by tricking the computer into thinking all tires are up to pressure just by placing the sensors into a piece of PVC tubing, and pressurize the tube. of course, this would have to be made, but very cheap and easy to do. as long as they are all reading a good pressure, they will tell the PCM all is well.... even if its just in a tube and not the wheels.
Old Jan 13, 2008 | 07:33 PM
BlueOvalFitter
Question
I'm a 26 year pipefitter by trade so this would be easy for me.But,my q? is where do you place the pipe?
Old Jan 13, 2008 | 08:47 PM
VFR_Man's Avatar
VFR_Man
...where do you place the pipe?
Any place that the sensors will be read, sounds like under the seat has worked.
Old Jan 13, 2008 | 09:40 PM
mattd17's Avatar
mattd17
sure.... under the seat, ziptied under the frame, etc..... just as long as they can send the signal to the PCM it will be tricked.
now of course, you wont know when you lose psi in a tire (according to the dash light), but then again.... IMO, is it really needed ???
Old Jan 15, 2008 | 09:26 AM
03redstx's Avatar
03redstx
fwiw, the light shut off by itself yesterday...i did nothing
Old Jan 16, 2008 | 12:56 PM
BigBlueMacDaddy's Avatar
BigBlueMacDaddy
03REDSTX, By all means, let us know if it comes back on! It would be great if they would ALL go off, and STAY off!
Old Jan 16, 2008 | 01:28 PM
03redstx's Avatar
03redstx
spoke too soon....came back on for a little bit....back off today though....i dont plan on doing anything for it...a couple months from now the factory rims and tires will be back on....
Old Jan 18, 2008 | 07:16 AM
03redstx's Avatar
03redstx
Smile
been off for a couple of days....i guess it gave up...no need to do anything with it
Old Jan 18, 2008 | 11:49 PM
wwilson43's Avatar
wwilson43
I read a link where you could get after market bands of the 18 inch Mustang rims, should work on an f150
Old Jan 24, 2008 | 11:08 AM
spikedog's Avatar
spikedog
Has anyone actually tried the pipe trick and had success? I've read where the sensors only wake up if they are in motion, which won't happen under the seat.
Old Jan 24, 2008 | 12:29 PM
  #28
BatteriesNotINCL's Avatar
BatteriesNotINCL
What would the dealer charge to redo the whole system...cuz my friends expy has a "flashing light"
Old Jan 24, 2008 | 12:47 PM
  #29
03redstx's Avatar
03redstx
mine flashes first then stays solid...it has been on for a day then off for a couple...annoying but not enough to make me waste the money....spring is right around the corner
Old Jan 25, 2008 | 12:53 AM
  #30
wwilson43's Avatar
wwilson43
Just to install new bands on after market rims and transfer the tires cost about 300.00, if you had to replace the monitors that would be even more expensive.
