Has anyone actually tried the pipe trick and had success? I've read where the sensors only wake up if they are in motion, which won't happen under the seat.
From a recent experience, I think Spike is right. FWIW, the TMPS light came on in my Subaru because of low pressure in one of the tires. The light didn't clear after I got the tire back to the normal range. The light cleared on the way to the dealership. The service guy said the alarm doesn't clear until normal pressure has been restored and the sensor spins at a minimum of about 40 to 45 mph for a couple of miles. I figure the Ford TMPS would be the same.
I also learned that the emergency "donut" spare doesn't have a sensor. Is there a sensor in the Ford full size spare tire?
Reason: Question about spare
The reason I said the PVC tube trick probably won't work is that a guy posted that he put his stock tires and rims in the bed of his pickup. He put on new rims/tires, and the stockers had the TPMS sensors in them. After days of driving, the TPMS alarms kept on coming. So I don't think the tube trick would work based on that.
I've pretty well bit the bullet and bought a set of used rims and TPMS sensors to use with my snow tires. Since the tire shops keep breaking the sensors off my stock rims, it seems to be the only way to go. $600 for snow tires and over $800 for the extra rims and TPMS. The only way I can justify that expense is by owning the Explorer for well over a decade.
In a previous string on resetting the TPMS, ford does have a device for 19.00 that resets the TPMS. The part no. that the service rep used is 8C2T-1A203-AB the one that the parts guy gave me is 8C2Z-1A203-A, he said that it does not list one for the 07 but this the one listed for the 08. To reset the TPMS you have to turn your key from off to start, (without starting the vehicle) 3 times and tap on the brake, do this untill the horn beeps and then reset the TPMS.
